Polk Momo C300.2 Birth Sheet
Systems
Systems Posts: 14,872
edited August 2004 in Car Audio & Electronics
Does anyone know if Polk can supply a birth sheet if you give the serial number of the AMP? Or even if they can just supply the specs?
FNG
Testing
Testing
Testing
  • Systems
    edited August 2004
    Anyone???
    Testing
    Testing
    Testing
  • MacLeod
    MacLeod Posts: 14,358
    edited August 2004
    Dont know but I can give you test results from 2 of their amps out of magazines.
    *500.1*
    Rated at 4 ohms - 350x1
    Tested at 4 ohms- 410x1 at 13.5 volts and 456x1 at 14.1 volts
    Rated at 2 ohms - 500x1
    Tested at 2 ohms- 617x1 at 13.5 volts and 691x1 at 14.1 volts
    *300.2*
    Rated at 4 ohms - 150x2
    Tested at 4 ohms - 140x2 at 12.5 volts, 165x2 at 14.4 volts
    Rated at 2 ohms - 220x2
    Tested at 2 ohms - 217x2 at 12.5 volts and 243x2 at 14.4 volts
    Rated bridged at 4 ohms - 550x1
    Tested bridged at 4 ohms - 447 at 12.5 volts and 507 at 14.4 volts
    The 500.1 was out of Performance Auto and Sound.
    the 300.2 is from Car Audio and Electronics.
  • exalted512
    exalted512 Posts: 10,734
    edited August 2004
    shame on Polk!;)
    -Cody
  • MacLeod
    edited August 2004
    LOL!
    Yeah but they make up for it with their 500.1 putting out nearly 700 watts!!!!
  • Systems
    edited August 2004
    So, should I look into differen't amp??? I've got 21 days to return it.
    FNG
    Testing
    Testing
    Testing
  • exalted512
    edited August 2004
    are you going to be bridging it?
    -Cody
  • bknauss
    bknauss Posts: 1,441
    edited August 2004
    Argh! That 550W bridged is a typo... should be 450W. Too bad its a typo both on the website and the literature.
    Brian Knauss
    ex-Electrical Engineer for Polk
  • MacLeod
    edited August 2004
    FNG
    Absolutley not! The Polk amps are very good. If youve already bought them, keep them!
  • bknauss
    edited August 2004
    Website has been updated and word has been sent out about the manuals:
    http://www.polkaudio.com/car/specs.php?name=c300_2
    Brian Knauss
  • exalted512
    edited August 2004
    thats one MAJOR typo...
    -Cody
  • bknauss
    edited August 2004
    I'm taking a wild guess that someone's finger slipped and then it went from there...
    Brian Knauss
