Polk Momo C300.2 Birth Sheet
Systems
Does anyone know if Polk can supply a birth sheet if you give the serial number of the AMP? Or even if they can just supply the specs?
FNG
FNG
Testing
Testing
Testing
Testing
Testing
Dont know but I can give you test results from 2 of their amps out of magazines.
*500.1*
Rated at 4 ohms - 350x1
Tested at 4 ohms- 410x1 at 13.5 volts and 456x1 at 14.1 volts
Rated at 2 ohms - 500x1
Tested at 2 ohms- 617x1 at 13.5 volts and 691x1 at 14.1 volts
*300.2*
Rated at 4 ohms - 150x2
Tested at 4 ohms - 140x2 at 12.5 volts, 165x2 at 14.4 volts
Rated at 2 ohms - 220x2
Tested at 2 ohms - 217x2 at 12.5 volts and 243x2 at 14.4 volts
Rated bridged at 4 ohms - 550x1
Tested bridged at 4 ohms - 447 at 12.5 volts and 507 at 14.4 volts
The 500.1 was out of Performance Auto and Sound.
the 300.2 is from Car Audio and Electronics.polkaudio sound quality competitor since 2005
shame on Polk!;)Originally posted by MacLeod
LOL!
Yeah but they make up for it with their 500.1 putting out nearly 700 watts!!!!polkaudio sound quality competitor since 2005
So, should I look into differen't amp??? I've got 21 days to return it.
FNGTesting
Testing
Testing -
are you going to be bridging it?
Argh! That 550W bridged is a typo... should be 450W. Too bad its a typo both on the website and the literature.Brian Knauss
ex-Electrical Engineer for Polk -
FNG
Absolutley not! The Polk amps are very good. If youve already bought them, keep them!polkaudio sound quality competitor since 2005
Website has been updated and word has been sent out about the manuals:
http://www.polkaudio.com/car/specs.php?name=c300_2Brian Knauss
thats one MAJOR typo...
I'm taking a wild guess that someone's finger slipped and then it went from there...Brian Knauss
