Can anyone tell me what the power rating is for the monitor series 10 II ?
nacki
I just picked these speakers up and would like to know the power rating of the Monitor 10 series II. I believe they are the series II by looking at the pic's of others. SN # is 161535 if that helps. Any help would be great. Thanks Nacki
Best Answer
Type: 3 way, 4 driver loudspeaker system
Frequency Response: 25Hz to 26kHz
Recommended Amplifier: 20 to 250W
Impedance: 6Ω
Sensitivity: 89dB
Bass: 1 x 10" fluid coupled
Midrange: 2 x 6.5" cone
Tweeter: 1 x 1" dome
Dimensions: 28 x 16 x 11.5 inchesThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Answers
Thanks for the help. Nacki
Monitor 10 Series 2 specs. from the Polk Monitor Series 2 brochure. Same info. as the previous post.
