Starting a new phonostage build.
Having completed my line stage, I need a phono stage for my vinyl. Here is the chassis I got off Ebay. There will be three tubes across the front.
  • Wardsweb
    Wardsweb Posts: 942
    Here is what I have so far for a layout. I was going to use a three socket turret board (seen at the top) but the one I got from AES is too big. I called them about the size not being what their website shows and they found out that all their inventory for the size I want is wrong. They need to return it to the manufacturer. I decided to go with a couple single row boards, rather than wait for them to get new stock.
    EndersShadow Posts: 17,700
    Man, your work makes me quite jealous. Gorgeous and its only going to look better.
    @DSkip you best get this guy your amps to look at lol, its QUITE obvious he's been around the block a few times (he might have even built it :smile: )
  • Have you considered an external power supply?
  • Wardsweb
    Wardsweb Posts: 942
    I did with the power supply taking up 3/4 of the chassis, but if I remove it, the chassis would seem a waste with only the phono section in it. This way it is simple clean and compact.
  • Are you using a passive or active RIAA EQ?
  • Wardsweb
    Wardsweb Posts: 942
    Three gain stages with one partial-equalization network in between each gain stage. Here is a great article on passive phono preamps and the many ways to build them.
    http://www.tubecad.com/articles_2002/RIAA_Preamps_Part_2/index.html
  • Yes, that site has been very helpful in learning about circuitry for me. I'm sure your project will as good looking as it is good sounding. Thanks for sharing the photos.
  • Wardsweb
    Wardsweb Posts: 942
    Thanks, I will add to this thread, as the build progresses. My projects typically take some time, as I want things to be just so. Perfection takes time.
  • Wardsweb
    Wardsweb Posts: 942
    Cutting is done. Here is what it looks like from the outside.
  • Wardsweb
    Wardsweb Posts: 942
    And from the inside with the transformer recessed.
  • dromunds
    dromunds Posts: 10,113
  • Wardsweb
    Wardsweb Posts: 942
    DSkip wrote: »
    I wish you lived closer. Texas is too damn big.
    This way it will help keep you out of trouble. No telling what mischief we would get into.
  • george daniel
    george daniel Posts: 12,096
    Nice work sir,,indeed!
    nooshinjohn Posts: 25,900
    That is looking sweet sir...
  • Wardsweb
    Wardsweb Posts: 942
    Things start to fill up fast with the addition of parts in a rough layout.
  • starkiller
    starkiller Posts: 2,723
    Wow! Very very nice...if it sounds as good as it looks you will need to start production of them immediately for us Polkies ! :)
    Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
  • vcwatkins
    vcwatkins Posts: 1,993
    Any updates?
  • Wardsweb
    Wardsweb Posts: 942
    Still in progress. It gets uglier before it gets pretty. At the moment, there are lots of extra wires going to resistors in the power supply. This is so I can swap resistors easier while working to get the voltages I want in the power supply. Once the determination is done, I then solder the value I need in place on the turret board.
  • vcwatkins
    Thanks, Wardsweb.
  • Wardsweb
    Wardsweb Posts: 942
    Life keeps getting in the way, but progress continues.
  • Jhayman
    Jhayman Posts: 1,548
    Looks Great and I'm sure it will sound Amazing once all dialled in..
  • Wardsweb
    Wardsweb Posts: 942
    Once it was back on the bench, things went very quickly. The phonostage is done.
  • Wardsweb
    Wardsweb Posts: 942
    The working side.
  • voltz
    voltz Posts: 5,384
    Wow! Stunning!
  • vcwatkins
    Beautiful! Any tasting notes?
    Where can I buy one...
  • Wardsweb
    Wardsweb Posts: 942
    DSkip wrote: »
    I'm still waiting on the verdict for those 845 amps.
    The 845's are keepers. They are here to stay. Still it would be nice to compare them to yours.
  • Wardsweb
    Wardsweb Posts: 942
    That is pure sexy!
