Starting a new phonostage build.
Wardsweb
Having completed my line stage, I need a phono stage for my vinyl. Here is the chassis I got off Ebay. There will be three tubes across the front.
Here is what I have so far for a layout. I was going to use a three socket turret board (seen at the top) but the one I got from AES is too big. I called them about the size not being what their website shows and they found out that all their inventory for the size I want is wrong. They need to return it to the manufacturer. I decided to go with a couple single row boards, rather than wait for them to get new stock.
Man, your work makes me quite jealous. Gorgeous and its only going to look better.
@DSkip you best get this guy your amps to look at lol, its QUITE obvious he's been around the block a few times (he might have even built it
) "....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Have you considered an external power supply?
Kenneth Swauger wrote: »Have you considered an external power supply?
I did with the power supply taking up 3/4 of the chassis, but if I remove it, the chassis would seem a waste with only the phono section in it. This way it is simple clean and compact. -
Are you using a passive or active RIAA EQ?
Kenneth Swauger wrote: »Are you using a passive or active RIAA EQ?
Three gain stages with one partial-equalization network in between each gain stage. Here is a great article on passive phono preamps and the many ways to build them.
http://www.tubecad.com/articles_2002/RIAA_Preamps_Part_2/index.html -
Yes, that site has been very helpful in learning about circuitry for me. I'm sure your project will as good looking as it is good sounding. Thanks for sharing the photos.
Kenneth Swauger wrote: »Yes, that site has been very helpful in learning about circuitry for me. I'm sure your project will as good looking as it is good sounding. Thanks for sharing the photos.
Thanks, I will add to this thread, as the build progresses. My projects typically take some time, as I want things to be just so. Perfection takes time. -
Cutting is done. Here is what it looks like from the outside.
And from the inside with the transformer recessed.
I salute you.
I wish you lived closer. Texas is too damn big.
This way it will help keep you out of trouble. No telling what mischief we would get into. -
That is looking sweet sir...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Things start to fill up fast with the addition of parts in a rough layout.
Wow! Very very nice...if it sounds as good as it looks you will need to start production of them immediately for us Polkies !
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC -
Any updates?Beach Audio: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
Town Porch: WiiM Pro Plus * Sunfire Sig II * Canare 4S11 * Magnepan 1.6 * Dectet -
Still in progress. It gets uglier before it gets pretty. At the moment, there are lots of extra wires going to resistors in the power supply. This is so I can swap resistors easier while working to get the voltages I want in the power supply. Once the determination is done, I then solder the value I need in place on the turret board.
Thanks, Wardsweb.Beach Audio: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
Life keeps getting in the way, but progress continues.
Looks Great and I'm sure it will sound Amazing once all dialled in..ATC SCM40's,VTL TL 2.5 Preamp,PSB Stratus Goldi's,McCormack DNA 500,McCormack MAP-1 Preamp,Pro-Ject Xtension 10 TT,Ortofon Cadenza Red/Nordost RedDawn LS Speaker cables, Bryston BDP-2, Bryston BDA-2,PS Audio AC-3 power cables
Once it was back on the bench, things went very quickly. The phonostage is done.
The working side.
Wow! Stunning!
Beautiful! Any tasting notes?Beach Audio: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
Where can I buy one...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
I'm still waiting on the verdict for those 845 amps.
The 845's are keepers. They are here to stay. Still it would be nice to compare them to yours. -
That is pure sexy!
