Wiring diagram for Polk Audio MM651
Hello, I need help wiring my speakers. I recently removed them for some mechanical work and now don't remember which way to wire them. What I mean is which wires from the crossover go to which terminals on the speaker? Thanks for any help as I don't want to mess them up.
  • Hello,
    Welcome to Polk's forum. If you look at the crossover with the connections to the right the upper connections are for the tweeter, the next ones are for the mid/bass driver and the lower most are for the power amplifier. The area on the side under where these connections are made will have the polarity.
    Regards, Ken
