Trouble Choosing Between Speakers
Greetings! I'm wanting to get a pair of speakers mainly for use with my computer. Family tradition dictates Polks, so I figured I may as well keep it going. At this point, I'm torn between the Monitor 40 Series 2 Bookshelf speakers and the Monitor 4 Series 2 Bookshelf speakers. Links to both will be in the bottom. Anyway, I need some input on how they sound. I was going to get a pair of Monitor 7s, but I have nowhere to put them and there's already a pair of Monitor 10's in the house. Any feedback is welcome!
Monitor 40: http://www.newegg.com/Product/Product.aspx?Item=N82E16882290202&cm_re=polk_audio-_-82-290-202-_-Product
Monitor 4: http://www.ebay.com/itm/POLK-AUDIO-MONITOR-4-SERIES-2-BOOKSHELF-SPEAKERS-EXCELLENT-CONDITION-/281552603032?pt=LH_DefaultDomain_0&hash=item418dd7c798
    tonyb Posts: 33,068
    Fairly big speakers to use for a computer. Those aren't computer speakers either. How do you plan on hooking them up to a computer ? Do you have other gear in the mix ?
  • Asus Xonar Essence STX Soundcard > RCA stereo outputs >Harman/Kardon HK725 pre-amp>Adcom GFA545 power-amp>Speakers. I know it's a little over-kill, but that's how I prefer it. I like things to sound good.
    tonyb Posts: 33,068
    Monitor 40's then.
  • If you've any better ideas, I'd like to hear them. I'm still considering the M7s as a purchase for later down the road.
    tonyb Posts: 33,068
    Well, you seem to like the Polk sound, just way too many choices out there to name them all. Depends on budget too, which you really didn't say.
  • For the speakers, I'd be okay with spending around $200 USD. Treating them as a bit of an investment for the time being. If there's something majorly better for a reasonable amount more, then I may look into it and see if it's something I'd want.
    tonyb Posts: 33,068
    I would stay with Polk then as 200 bucks isn't going to buy a whole lot in a standard bookie. Unless you don't mind buying used.
  • ROHfan
    ROHfan Posts: 1,014
    They may be slightly above your budget but the Wharfedale Diamond 10.1's look pretty nice and are well reviewed. When I take my SDA 2's out of commission temporarily for veneer work I may be getting those speakers to hold me over and to experiment with.
    Another pair would be the Pioneer SP-BS22-LR designed by Andrew Jones. For around $125 these speakers supposedly sound way better than they should, from what I've read. I may pick these up one day just to play around with.
    TV: 65" Samsung QLED 4K
    AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
  • I went down to the local Best Buy as I remembered that had something from Polk there. They were little $100 bookshelf speakers that sounded like they were underwater the entire time. As much as I hate to say it, a pair of Sony speakers were the best sounding bookshelf speakers they had there. I'm going to do some calling around today to see if I can find anyone with the Polks I'm interested in, but if not, I may go with they Sony speakers. I was actually impressed with how they sounded. Link to them here: http://www.amazon.com/Sony-SSCS5-3-Driver-Bookshelf-Speaker/dp/B00O8YLMVA#customerReviews
  • scotvl
    scotvl Posts: 88
    if you have a chance to listen to some Rti4s you might like what you hear, my son has them in his bedroom for his computer and Xbox one hooked up to my old Yamaha rx-v665 and they sound awesome even without a sub.
    amazon.com/Polk-Audio-Performance-Bookshelf-Speakers/dp/B0000E2XEB/ref=sr_1_1?s=electronics&ie=UTF8&qid=1422977619&sr=1-1&keywords=rti4
  • from the PC, Polk TL3s and a good sub, but that's more than 2 bones. Yes I see the pre and amp there.
  • Not familiar with add-on subs. I know the power amp doesn't have outputs for anything other than the the two speaker channels. Not sure about the pre-amp. Haven't looked at the back of it in ages.
    tonyb Posts: 33,068
    Epos would be another good one, Energy....NHT both make good bookies too.
  • scotvl
    scotvl Posts: 88
    edited February 2015
    I wouldn't buy that hk3370 for $150.00, its circa 2003 and no hdmi none of the newer codecs. Head down to a couple Bestbuys in your area and look at their open box avrs, You will be surprised at the great deals you can get. I picked up my sc-1227 for $350.00can open box at Futureshop and it is a beast of an avr with all the new audio codecs, airplay, hi res playback through usb, plus many more features. Plus you get a full warranty vs buying something used off of ebay. I'm just saying what I would do there are a lot of good avr deals if you search.
  • I'm actually not at all interested in things like that. The main reason I'm interested in that is the ability to hook up a subwoofer. I'd be happy if I could get a power amp that's either got a sub-out or two speaker sets as the sub I'm looking at accepts both as input (though I've no idea which is better.) If you can list an amp in that price range that meets that, by all means.
  • Should have mentioned that I already have the Harmon/Kardon HK725 pre-amp sitting on my desk. Use it as a headphone amp from time to time.
  • seabeerob213
    seabeerob213 Posts: 1,843
    Find an HK 3490, love mine, amp pre outs, 2 sub pre outs, 2x 2 channel speaker outs, and they'll drive a lot of tougher to drive speakers pretty well for a stereo receiver. I believe it can handle four ohm, but don't quote me on that. Takes coax or optical for digital, even if only one of each. Has analog in as well, maybe able to run from the pre to it, although idk if there will be much benefit had there.
  • Easy answer, the 5jr.
    Joey Ward
  • Nightfall
    Nightfall Posts: 10,084
    Buy from Rick with confidence in every aspect, if that's the route you take.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • I wish I had a place to go and listen to the RC-10s. I actually found a pair of Sony speakers (I know it's a sin) that I really like the sound of. You're offing the RC-10s for the same price. I wish there was some way I could go and compare the two. Link to the Sony speakers here: http://www.amazon.com/Sony-SSCS5-3-Driver-Bookshelf-Speaker/dp/B00O8YLMVA/ref=sr_1_2?s=electronics&ie=UTF8&qid=1423163760&sr=1-2&keywords=sony+cs+ss
  • ROHfan
    ROHfan Posts: 1,014
    If you don't take those RC-10s, I will. You'll probably hate them anyway :)
  • Hue. Why would that be?
  • I'll give the M-10's a pass. Family friend said I wouldn't care for them.
  • Well, this has just gotten out of hand. It's either a pair of Polk M7s or Polk SDAs. So much for bookshelf speaker.
  • ROHfan
    ROHfan Posts: 1,014
    Yay for me!!
  • trj
    trj Posts: 320
    If you really want polks, check fry's. They are having awesome sale on polks till tomorrow. I even saw RTiA1's for $50 a pair. I don't know your location OP, but they are in store only. No fry's here in Denver.
    I might buy CSi3 for $99 with free shipping. Still on the fence, if I should go with CSi
    Sony BDP-S6500 | Raspberry Pi 2 | XBOX One S | Wii --> Yamaha RX-V667 --> Adcom 5006 bridged to 175 watts for front LCR -- >Front: Polk Audio RTi8s | Center: CSi5 | Side Surrounds: RTi4s | Rear surrounds: FXiA4s | Cheap 12" sub woofer|Samsung UN60KU6300
  • ROHfan
    ROHfan Posts: 1,014
    Rick88 wrote: »
    ROHfan wrote: »
    Yay for me!!
    They are yours then. I am getting ready for work, and will be busy tomorrrow, but I'll be in contact with you tomorrow evening...
    Changed my mind.
    Joking. Talk to you tomorrow.
  • Went to a local audio store on a whim to see what they had laying around. There's now a pair of Polk Monitor 7's sitting in the living room awaiting a cross-over rebuild. Thanks for the feedback, guys!
