Ceiling Mount for RM75 speakers
Rob26Smith
I'm trying to find some ceiling mounts for the rm75 speakers. Since the hole is at the bottom of the speaker all the mounts I find don't seem compatible. All of them seem to point the speaker straight down, I want it on an angle. Can someone give me a suggestion? Thank you in advance.
I have the same question. Are there are any ceiling mounts for the RM75 speakers?
Hello,
Welcome to Polk's forum. The threaded opening is 1/4" diameter #20 thread size. I believe the best choice is to use the Omnimount 10 series of wall mount brackets. If you contact them and explain what you're looking for they can make a specific recommendation.
Regards, Ken
