Does Mills make 1.3 ohm resistors?
I need a couple to redo the crossovers in my 5jr. If Mills does not make 1.3 ohm, should I use 2 in series to make a 1.3 or just use a single 1.2 ohm and call it a day?
Best Answer
    F1nut Posts: 52,000
    Answer ✓
    Believe it or not .1makes a difference. If using the SL2000 I would go with 1.4, if the new tweeter go with the 1.2.
Answers
    F1nut Posts: 52,000
    You can easily check by looking here, http://www.soniccraft.com/
  • Hofy
    Hofy Posts: 169
    Thanks for answering F1nut, but soniccraft was the first place I checked. I didnt see any 1.3 ohm resistors so that is why I am asking here. I take it that Mills does not make 1.3 ohm so that leads to my other question. 2 resistors in series or a single 1.2?
    F1nut Posts: 52,000
    Ok, which tweeter are you using?
  • Hofy
    Hofy Posts: 169
    Currently SL2000 with possible PDO-194 in the future. This is in Monitor 5jr blow hole (no PR). Crazy thing is the SL2000 sounds better than the Peerless in my 5A. Ofcourse both need crossovers rebuilt, so I will not know what I like better until then.
