Tech flex question
What diameter of tech flex jacket for 2 separate 12 Awg speaker cables in same jacket.....seems 3/4 is way too big and sloppy looking. Thx
    SCompRacer Posts: 9,093
    edited January 2015
    Flexo PET claims theirs expands up to 150%. It's good to have it stretch a little installed so it's a snug fit.
    Here is a chart I found at a car forum that can be used as a guide.
    F1nut Posts: 51,722
    Two separate cables in a single TechFlex jacket? That's not going to look good.
  • Moose68Bash
    Moose68Bash Posts: 3,843
    Tech flex is just one more dialectric on the cables.
    Is the chance that it will affect SQ worth the aesthetic improvement of the cables?
    Or do you have another reason for wanting to put the -- I assume -- double-run, bi-wire cables in tech flex?
  • kevhed72
    kevhed72 Posts: 5,139
    These are diy cables to use the high level inputs on the sub I just scored. They are simply 12 Awg low voltage cable I had sitting around, doubled up and twisted the ends for each channel. Screw set nanners I also had forever, so I my thought was 3/8 tech flex.
