New AMP for 1.2'stl
VCoak
Good day and hope everyone had a good Christmas;
I am in looking into mono amps to replace my adcom 5500. I'm currently running my 1.2tl (mod. from VR3) thru a gfp-750 pre>gfa 5500. No turntable, all digital at this time. Using the W4S DAC 2 DSDse with a mac mini and NAS. I also have an older monster avs 2000 signature in use. My budget is 3000.00. +/- .
I have clipped the 5500 a few times to see the wow that is loud factor...Genre is mostly Jazz, classical, classic rock, country; in that order.
Will be installing a dedicated 20amp very soon. Also ran the system w/o the pre and yes there is a quality of sound change. The pre adds a bit of warmth.
Clarity is critical with a touch of volume. Thanks Gents in advance
oak
oak
W4S SX-1000, Adcom gfp-750, Polk 1.2tl, W4S DAC 2 DSDse, 2012 mac mini (mod), JRivers ver. 19, WD Cloud NAS 2 t.b., Monster Cable AVS-2000 signature, Doug's Alpha I/C & Doug's biwire 6' speaker cables
I have had the great opportunity to own a pair of them for about 5 years or so. It wasn't until I paired them with the equally great Carver signature Sunfire Grand Home Theartre Amp. Combining the front channels and the surround channels in a biamp config. did the big boys show their full prowess. I was and still is the best sound I ever heard.Joe
As of now they will be for 2-channel music but very interesting thought for HT, hmmmW4S SX-1000, Adcom gfp-750, Polk 1.2tl, W4S DAC 2 DSDse, 2012 mac mini (mod), JRivers ver. 19, WD Cloud NAS 2 t.b., Monster Cable AVS-2000 signature, Doug's Alpha I/C & Doug's biwire 6' speaker cables
Do you have the AI-1 or Dreadnought?Political Correctness'.........defined
President of Club Polk -
I have the dreadnought. Built an 800 last winter. Works very well.W4S SX-1000, Adcom gfp-750, Polk 1.2tl, W4S DAC 2 DSDse, 2012 mac mini (mod), JRivers ver. 19, WD Cloud NAS 2 t.b., Monster Cable AVS-2000 signature, Doug's Alpha I/C & Doug's biwire 6' speaker cables
With that budget you really opened the door to a nice choice of amps.
even the Musical Fidelity M6si Integrated Amplifier is $2999 new, to bad you can't find one used but I don't think anyone ever gets rid of one.2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
I had similar gear until changing just the pre recently: SBTouch, W4S Dac1 (upped to 2 spec), gfp-750, 1.2's (fully modded but not tl'd), Dreadnought.
I LOVE my Sunfire Sig II (625w x 2) that I bought here and would encourage you to try one if possible (and if you'd consider a used SS 2-channel).
Haven't tried mono blocks. My budget was $1-2k, which is likely to be as much as I ever put into a SS 2ch for this den rig. Looking to try a tube integrated on this rig soon.
Best of luck in your search,
Craig
Town Porch: WiiM Pro Plus * Sunfire Sig II * Canare 4S11 * Magnepan 1.6 * Dectet -
BTW, if interested, I wrote a few brief remarks about that amp at the end of the FS thread here: http://forum.polkaudio.com/discussion/155674/sunfire-sig-ii-625x2Beach Audio: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
Thank you voltz & vcwatkins.
W4S SX-1000, Adcom gfp-750, Polk 1.2tl, W4S DAC 2 DSDse, 2012 mac mini (mod), JRivers ver. 19, WD Cloud NAS 2 t.b., Monster Cable AVS-2000 signature, Doug's Alpha I/C & Doug's biwire 6' speaker cables -
The two I'de love to own I have a feeling are going to be too expensive because I didn't ask the cost. Dan D'Agostino or Doshi Audio. The Doshi's are tubes and I heard them yesterday paired with Wilson Audio XLF's.
Never mind. I just saw a used Doshi pre on the 'gon for $6K with a new price of $15K.2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout. -
Tube amps are definitely to be considered. Though I personally have not owned one before but many folks swear by them. My first concern would be the speakers and their need for power. A ball park idea on watts needed??? and mono or stereo make that much of a difference in tubes?W4S SX-1000, Adcom gfp-750, Polk 1.2tl, W4S DAC 2 DSDse, 2012 mac mini (mod), JRivers ver. 19, WD Cloud NAS 2 t.b., Monster Cable AVS-2000 signature, Doug's Alpha I/C & Doug's biwire 6' speaker cables
I run a pair of push-pull mono's in the 350 watt range and find the amps more than capable of allowing the 1.2TL to really come to life in a very BIG way.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Thank you on the Carver info. Tomorrow sound testing a pair of wyred 4 sound sx-1000's. Seller is allowing. Never heard of the amps but own their dac (DAC2 DSDse)W4S SX-1000, Adcom gfp-750, Polk 1.2tl, W4S DAC 2 DSDse, 2012 mac mini (mod), JRivers ver. 19, WD Cloud NAS 2 t.b., Monster Cable AVS-2000 signature, Doug's Alpha I/C & Doug's biwire 6' speaker cables
+1 on Krell. I've got a KAV-2250 that easily handles my 4.1TL's, and it used to drive 1C's with ease. My advice is stick with a solid state amp and get a tube preamp.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
Yeah, I agree with npindel on both the tube pre/solid state amp rec and the Krell suggestion as well.
My Dared sl2000/Krell 250/4.1tl combo was fantastic. Big regrets letting that amp go. Stupid. It just didn't play as well in the Dared/SRS2 main rig at the time. Didn't know it at the time, but it was due to associated gear, not the Krell.Beach Audio: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
+1! I run my 2.3TL's with a Sunfire Signature Grande 400x5. Fantastic sound and plenty of headroom. I've also run them with a Parasound Halo A51. Both amps have similar sound signatures with the nod to the Sunfire in the bass department. It also runs much cooler than the Parasound. I think you would fine either of their sound qualities more pleasing to the ear than the Adcom. The GFA7500 I owned a few years back seemed harsh to me ears.
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, McIntosh C2300, Marantz AV7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Sim Audio Moon 380D DAC, EPSON Pro Cinema 6050 -
I pulled the trigger on a set of W4S SX-1000's. Finished the setup. Talk about amps that can push! Very neutral but clean in all volumes. Plus I found a bad speaker connection in my cabling.
Overall I am pleased and so is my electrical bill...
Tube pre-amp might be in the future... Thank you all for your input and advice.W4S SX-1000, Adcom gfp-750, Polk 1.2tl, W4S DAC 2 DSDse, 2012 mac mini (mod), JRivers ver. 19, WD Cloud NAS 2 t.b., Monster Cable AVS-2000 signature, Doug's Alpha I/C & Doug's biwire 6' speaker cables -
Cool man, glad you like them. Go on the hunt for a decent tubed pre, they mate well with SDA's.HT SYSTEM-
lsi 9's -
thx T. Working on a set of either doug's cables or acoustic zen.W4S SX-1000, Adcom gfp-750, Polk 1.2tl, W4S DAC 2 DSDse, 2012 mac mini (mod), JRivers ver. 19, WD Cloud NAS 2 t.b., Monster Cable AVS-2000 signature, Doug's Alpha I/C & Doug's biwire 6' speaker cables
BTW the new amps have a slight buzz sound. Moved around some ic's but didn't help. Will try to by pass the preamp and also try plugging them directly to an outlet. currently they are powered via the monster cable avs-2000.W4S SX-1000, Adcom gfp-750, Polk 1.2tl, W4S DAC 2 DSDse, 2012 mac mini (mod), JRivers ver. 19, WD Cloud NAS 2 t.b., Monster Cable AVS-2000 signature, Doug's Alpha I/C & Doug's biwire 6' speaker cables
Ugg....take those monos off the Monster PC pronto pal. What Ic's are you using to hook those bad boys up ?HT SYSTEM-
lsi 9's -
I am using doug's alpha ic rca. Will let you know when I D/C the Monster. Thx for the info.W4S SX-1000, Adcom gfp-750, Polk 1.2tl, W4S DAC 2 DSDse, 2012 mac mini (mod), JRivers ver. 19, WD Cloud NAS 2 t.b., Monster Cable AVS-2000 signature, Doug's Alpha I/C & Doug's biwire 6' speaker cables
Cool, if your going to use a PC'er, use one that's not current limiting.HT SYSTEM-
lsi 9's -
I have used the P/C for over ten years. I will to bet sound improves. Also looking at either dougs speaker cables or acoustic zen. A-gon has some decent prices nowW4S SX-1000, Adcom gfp-750, Polk 1.2tl, W4S DAC 2 DSDse, 2012 mac mini (mod), JRivers ver. 19, WD Cloud NAS 2 t.b., Monster Cable AVS-2000 signature, Doug's Alpha I/C & Doug's biwire 6' speaker cables
If you really want to up your game, I recommend MIT Shotgun S1's for your set up.
I agree with Tony, get those amps off the Monster AVS-2000
I'm limited with outlets only two currently. I am thinking of pulling a 20 am circuit just for the audio only. How do you guys run your hardware if I may ask.W4S SX-1000, Adcom gfp-750, Polk 1.2tl, W4S DAC 2 DSDse, 2012 mac mini (mod), JRivers ver. 19, WD Cloud NAS 2 t.b., Monster Cable AVS-2000 signature, Doug's Alpha I/C & Doug's biwire 6' speaker cables
MIT now that would be nice.W4S SX-1000, Adcom gfp-750, Polk 1.2tl, W4S DAC 2 DSDse, 2012 mac mini (mod), JRivers ver. 19, WD Cloud NAS 2 t.b., Monster Cable AVS-2000 signature, Doug's Alpha I/C & Doug's biwire 6' speaker cables
Joe Abrams on Audiogon has some excellent deals on MIT Shotgun cables. If you don't see any S1's listed, just give him a call.How do you guys run your hardware if I may ask.
All my rigs except one are on dedicated 20 amp circuits. The other one is on a dedicated 30 amp line. Whatever you do, pull 10 gauge. Well worth the extra cost.
Thank you I truly enjoy learning about this never ending quest. Time to hire an electrician.W4S SX-1000, Adcom gfp-750, Polk 1.2tl, W4S DAC 2 DSDse, 2012 mac mini (mod), JRivers ver. 19, WD Cloud NAS 2 t.b., Monster Cable AVS-2000 signature, Doug's Alpha I/C & Doug's biwire 6' speaker cables
BTW, Any polkie's that you know in San Diego area. Have yet to see one..W4S SX-1000, Adcom gfp-750, Polk 1.2tl, W4S DAC 2 DSDse, 2012 mac mini (mod), JRivers ver. 19, WD Cloud NAS 2 t.b., Monster Cable AVS-2000 signature, Doug's Alpha I/C & Doug's biwire 6' speaker cables
They usually don't like to work with 10 gauge and may even tell you don't need it, which you don't for a 20 amp line, but insist on it anyway.BTW, Any polkie's that you know in San Diego area.
There's a few on here, dpowell is and I think BlueFox is around there.Political Correctness'.........defined
