Black Hole 5
Sea
I need some black hole 5. I can only find Speaker City in CA that appears to carry it now. I ordered some mid December and it looks like they are having trouble getting it from supplier. Parts Express web site says no longer available. Is this product still being produced? Is there an alternative product?
Main-Carver TFM35(2),Carver C11 ,Carver SD/A 360 CD,Carver TX11 ,Grace Digital Tuner, Pioneer PL707 TT,Polk SDA1C
Downstairs -Carver M1.5t, Carver C1 Pre, Carver TX10 Tuner, Carver TL3200 CD Player, Dual 1009 TT,Polk SDA SRS 2.3tl
Study - Carver AV634 Amp, Carver CT7 Pre, Carver DTL50 CD Player, Polk RTA12c
www.soniccraft.com
Thanks.Main-Carver TFM35(2),Carver C11 ,Carver SD/A 360 CD,Carver TX11 ,Grace Digital Tuner, Pioneer PL707 TT,Polk SDA1C
Study - Carver AV634 Amp, Carver CT7 Pre, Carver DTL50 CD Player, Polk RTA12c -
If and when you get you sheets be very careful.This stuff works as advertised.When I did my 2Bs I almost tore it out it deadened the upper cabinet so dramatically I was shocked. I did eventually leave it in and got used to the more solid sound between the Dynamatt and B-H5. I got my sheet and many scraps off C/L for $18 and still might have some if I can find it. Awesome product. I tried to capture a pix of my installation but the back flash obscured it all....2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
Sea, how many pair of SDA's do you have now?
Eric, still just two. I am accumulating the parts to mod the 2.3tl's I got from you. The 1C's are totally done includig the dreadnaught. They are fantastic.Main-Carver TFM35(2),Carver C11 ,Carver SD/A 360 CD,Carver TX11 ,Grace Digital Tuner, Pioneer PL707 TT,Polk SDA1C
Are the 1C the studio black version or standard wood cap models?
Wood Cap.
Those look fantastic. I do miss the 2.3's for sure.
I think I like your
r end caps better than mine
