Yamaha RX-V375 and Polk PSW10
My Yamaha receiver has a SW PRE OUT jack, but my new Polk SW has no corresponding input. When I used a red/white RCA cable from the AUDIO OUT jacks to the L/R inputs, there seemed to be no connection. Any advice would be appreciated.
Answers
  • UPDATE: Issue fixed with addition of adapter that splits SW OUT cable into RCA jacks.
    nooshinjohn Posts: 25,916
    edited December 2014
    That would have been my suggestion...
  • You don't even need an adapter. Just choose either left or right. There is no benefit from splitting a mono signal to feed the l/r inputs of a mono amp. The signal is going to the same place.
  • Get a better sub?
    msg Posts: 10,452
    damn guys, that's a little harsh, isn't it? :)
    guy's just trying to get his sub working.
    +1 to what JM said - just pick one of the ins to use
  • Thanks for your comment, msg. Since this is my first time on the forum, I was afraid seebee's childish post might be typical.
  • Sorry bout that, been a rough week followed buy having to work my only day off in a span of 12-13 daysdays, was in a very cynical, sarcastic, and outspoken mood then, shouldn't have made any posts
