WTB rubber speaker spike feet (foot) for LSIM705/707
I lost one. Need just one or will buy more if you want to sell them all. Polk quoted me $60 for a set of 8 and i need just one. LMK.
Open to suggestions on alternatives that would be cheaper and work with the stock spikes. Also open to replacing spikes and rubbers if there is a better alternative. thanks.
    edited December 2014
    Carpet or hard floors ?
    You really don't want to use those rubber junk on carpets, won't anchor the speakers bass. Use spikes...if you have wood floors they sell small disc's to protect the floor.
    Post edited by tonyb on
  • Thanks for the advice, Tony. I was hoping to get the rubber feet in case i sell or put them on a hard surface some day. they are currently on carpet and i am using the spikes.
    Even on a hard surface, you should still use spikes and the floor protecting saucers they sell. If your a cheap ****, then put a tile under them from home depot. The whole point is to anchor the speaker, rubber on anything doesn't cut the mustard.
  • Thanks again. I am pretty much only looking for the spikes for the purpose of having them and not using them. My speakers aren't leaving the carpeted room they are in while i own them unless i buy another house. I am a cheap ****, however, as I only have $900 in my current rig. Can't justify spending $60+ for spike rubbers I have no use for.
