Review: Furez silver plated copper banana plugs
drumminman
drumminman Posts: 3,396
edited December 2014 in DIY, Mods & Tweaks
I’ve had these for a year or so and decided to go ahead and reterminate my diy braided Cat 5 speaker cables (Chris Venhaus recipe). I’ve had these cables in my system for many years and never felt the need to upgrade. They’re well balanced, with great imaging and detail, and contribute to an impressive sound stage.
I’ve been using gold plated brass compression bananas which have perfomed well. However, since I had the Furez on hand which I bought to try a new diy cable recipe I decided to go ahead and use them in the 2 channel rig. Available from Douglas Connections
http://www.douglasconnection.com/Furez-TSTSB60Ag-Silver-Plated-Banana-Plug-Connector-Pair-FZTSTSB60Ag.htm
they're constructed of silver plated tellurium copper with a conductivity of 105% IACS. Gold plated brass is around 40%, so I was hoping for an audible difference.
Not sure if burn in is applicable to banana plugs, but if it is I’m in for a real treat. I played music I’m familiar with to be able to note any changes and upon hitting the play button on the first CD, Bonnie Raitt’s “Silver Linings” I could tell something was different. The best overall description I can give is the sound from the speakers was thinner, less wooly, but more correct with a better frequency balance. So far this am I’ve played Madeline Peyroux, The Handsome Family (the folks who did the theme song for True Detective) and presently Annie Lennox’ Nostalgia)
The bass is more powerful, with greater slam, but slightly less bloated. Vocals are crystalline, pure, better tone, somehow cleaner. Drums and cymbals have transients that are more realistic, which is not something that was lacking before. In fact, I thought everything was already correct, but it was not until I heard the system with these Furez that I realized there could be improvement without replacing components.
The soundstage is about as wide as before, but with greater front to back depth. Subtle percussion and background instruments are more noticeable, as are individual instruments within complex passages. Horns, organs the tinkle of pianos all have a richer, more live "you are there" tone. The rig is also louder at the same volume settings on the linestage.
These tweaks costs around $100 for 8 connectors and for me is easily worth it.
  • voltz
    voltz Posts: 5,384
    Nice review! I aim using almost the same connectors on 2 pairs of my cables and have a full unused nannor set for future projects. one set is screwed down the other is the crimp.
  • Those are some excellent connectors. Glad you found them to be a nice upgrade :)
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    drumminman wrote: »
    . but it was not until I heard the system with these Furez that I realized there could be improvement without replacing components.
    Cha-ching.....that pretty much sums up the whole cable debate in general. Glad you like your new connectors. Send Doug a Christmas card....with a Starbucks gift card to keep him jazzed up making cables.
