Will i get better sound From a designated sub cable?
Will i get better sound From a designated sub cable? I am currently using Monster component cables to my two subs. Thanks for any input here :)
Answers
  • Csa73
    Csa73 Posts: 36
    Here is my set up:
    Yamaha HTR-6180
    Polk Monitor 75t
    Polk CSi5
    Polk F/Xi3
    Polk RTi6
    Polk PSW 505
    Polk PSW 12
    55" Samsung 8000
    PS4
    PS3
  • Talking about sound quality, your center doesn't seem to match your mains
    Isn't it an issue to your ears?
    RTiA5 + CSiA4 + Jamo SW410E
    Yamaha TSR-700 (equivalent to RX V6A)
    No surround...yet
    I don't have any issue with his center, it's a darn fine one at that. The csi5 can match a few different lines, it isn't beholden to one and same can be said for most the other higher line centers.
    Now to answer his question, yes....possibly anything other than monster stuff should give you better performance. Call Signal cable, BJC, or our very own DouglasConnections to get you a decent cable.
  • Csa73
    Csa73 Posts: 36
    Thanks tonyb. I will get right on it !! :)
