One speaker suddenly playing louder
Though process of elimination, it turns out I have one of my MIT t2 speaker cables playing louder than the other. Anyone ever have this happen?
ChrisIntegrated Amp: Cary SI-300D Processor: Marantz SR7012 Streaming: Bluesound Node 2I 4K Bluray: Panasonic UB820Mains: Von Schweikert VR2Center: Von Schweikert LCR15 Subs: 2 SVS Sb13 Ultra (HT Only) Analysis Plus Cables
    tonyb Posts: 33,072
    Nope....you sure ? Did your due diligence ? Switch cables from left to right ? Maybe one is playing quieter than another or one speaker is playing quieter giving the impression the other is louder.
    Not an amp channel going bad ? Call MIT and see what they say.
  • Msabot1
    Msabot1 Posts: 2,098
    Balance not adjusted? Stupid question..but sometimes the most obvious is the ones that get overlooked....
  • dagame27
    dagame27 Posts: 599
    All due diligence done. I ended up swapping in a spare signal cable speaker cable, which fixed the problem. It was definitely the speaker wire. I figured for sure it would have been my amp.
