just curious
Willow
Willow Posts: 11,228
where do peeps connect their speaker cables ? top or bottom binding posts ?
mine are on top
Post edited by Willow on
  • maggiefan
    maggiefan Posts: 223
    edited August 2004
    As long as your jumper strips are in place, it shouldn't matter.
    Larry
  • steveinaz
    steveinaz Posts: 19,545
    edited August 2004
    If it's keeping you up nights, connect to the top, that way bass tones are traversing the jumper, instead of delicate mid/high frequencies---then again, for such a miniscule run, it probably doesn't make much (if any) difference.
  • Willow
    edited August 2004
    doesn't keep me up just curious thats all
