just curious
Willow
where do peeps connect their speaker cables ? top or bottom binding posts ?
mine are on top
mine are on top
Post edited by Willow on
As long as your jumper strips are in place, it shouldn't matter.Larry
If it's keeping you up nights, connect to the top, that way bass tones are traversing the jumper, instead of delicate mid/high frequencies---then again, for such a miniscule run, it probably doesn't make much (if any) difference.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
doesn't keep me up just curious thats all
