Is Club Polk still around? I was a member a few yrs back but haven't used the site since.
I own a pair of RTA 12Cs from the mid 80s. My amp is an ADCOM GFA 555 and the preamp is ADCOM GTP 500. I had the mid range on at least one replaced 15 yrs ago because it blew and now the same thing happened again to both possibly. Is it a problem caused by the ADCOM equipment?? Sometimes at high volume the speakers shut down. Again is this a compatibility issue. How can I test them and replace what is damaged? Thank you.
Answers
  • vmaxer
    vmaxer Posts: 5,120
    Hi, this is the replacement to Club Polk..
    As far as the speakers, are you driving them into clipping the amp??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    F1nut Posts: 51,663
    With the recent and regrettable format change, Club Polk is a shell of what it use to be.
    You're overdriving the amp causing it to send clipped signals to the speakers. Either keep the volume level lower or buy a better, more powerful amp.
    edited November 2014
    That Adcom is pretty capable and usually VERY reliable. I'd look into having it serviced. Get someone to look at it, it's getting old and age never helps an amp.
    You should not be blowing things up unless you're clipping and if you're clipping those speakers with that amp, something is UP!
    As for Club Polk. Yeah, it's sorta still here but with a VERY heavy and controlling hand which perhaps even infantilizes some, or so it seems!
    cnh
  • Jim G
    Jim G Posts: 2
    Thank you all for responding. I will have the equipment serviced.
