Surrounds question
What do you think of the comparison between the Fxi5 and Fxi3? I've ordered the 3's but am now wondering if I'll wish I had the 5's. My thought was the the 3's should be enough for my room and would still match up well with the Csi5 and Rti8. Now I'm getting crazy and thinking I should have gotten the bigger ones. Help? Has anybody had them both? My room is 11x22 and they'll be mounted on the side walls as a part of a 7.1 setup. Thanks
Sony 57" WS HDTV
Denon 3805
Denon DVD-910
Monster Power HTS2600
Rti8 - Fronts
Csi5 - Center
Fxi3 - Surrounds
Rti4 - Rear Surrounds
SVS 20-39 Pci
Denon 3805
Denon DVD-910
Rti8 - Fronts
Csi5 - Center
Fxi3 - Surrounds
SVS 20-39 Pci
Post edited by MaC03 on
Well that's not an incredibly huge room AND you will be running 7.1...I think you'll be fine...
My room is a few feet shorter and I used the FX300's before upgrading. You'll be fine with the 3's
Agreed. In your case there's probably not much benefit in moving up to the 5's.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
thanks all for the replies, that's what I was hoping. I can't wait to get it all up!
Sony 57" WS HDTV
Denon 3805
Denon DVD-910
Rti8 - Fronts
Csi5 - Center
Fxi3 - Surrounds
SVS 20-39 Pci -
I should probably come back to this question later when I'm actually putting the speakers up. But has anyone experimented with corner placement for the rear of the 7.1? They have to be in the corners, so it's either facing each other or towards the room somewhere. If anything, I don't want them pointing down at all right?Sony 57" WS HDTV
Denon 3805
Denon DVD-910
Rti8 - Fronts
Csi5 - Center
Fxi3 - Surrounds
SVS 20-39 Pci
