Towers/Centre speaker combination
PeteD
PeteD Posts: 19
I am about to buy a pair of TSi500's what would be the best Polk centre speaker to match these towers?
I currently have a Polk RM7.
Best Answer
    gudnoyez Posts: 8,174
    Answer ✓
    The CS20 is the match for your TSI 500s so that would be the one to get, unless your looking for a center that does not match.
Answers
  • PeteD
    PeteD Posts: 19
    Relatively new to this
  • Mikey081057
    Mikey081057 Posts: 7,127
    TSx250c is probably the best match
    Garage | Polk Monitor 5B's
    I would say the CS20 would would be the perfect match as those are part of the TSI line.
    edited October 2014
    http://m.ebay.com/itm/390945936461?_mwBanner=1
    Here is one off of Polks E Bay store not sure what color you need. That is a decent price for sure.
    gudnoyez is right. But if you can't find that the CS2 would also be a close match. Almost identical drivers with a very slight difference in the crossover, negligible!
    cnh
  • PeteD
    PeteD Posts: 19
    Thanks guys for the info, right now I can get the TSx250c for less than the CS20. Can find info on the CS10 on Polk site but nothing on the CS20, no longer manufactured?
  • PeteD
    PeteD Posts: 19
    OK got the two TSi500's and both the CS20 and TSx250c are available for about the same price, so which way to go for sure?
  • PeteD
    PeteD Posts: 19
    Sorry again one last time if I got the tsx250c would that make much difference?
  • PeteD
    PeteD Posts: 19
    Thanks Gydnoyez will do as you say
