Impedance question...
RTiA7's are 8 ohm speakers and are bi-ampable. When bi-amped, what is the impedance each amp is shown? Still 8 ohms? 4 ohms? Thanks in advance.
AVR: Integra DTR-50.4
TV: LG 50PS70
DVD/CD/BR: OPPO BDP 93
MAINS: Polk RTiA7
CENTER: Polk CSiA6
Heights: Polk VS 625RT (in wall)
SURROUNDS: Polk TC60i (in ceiling)
REARS: Polk R1
SUB: Polk PSW 125
    F1nut Posts: 52,002
    You cannot bi-amp with an AVR, period. Bi-amping require separate amps, each with its own power supply, not a shared power supply like every AVR made. Bi-amping also requires the use of active crossovers. You want better sound, replace the stock plate jumpers with high quality speaker cable.
  • Upstatemax
    Upstatemax Posts: 2,800
    8 ohms.
    If using a receiver don't expect a huge difference if any. On my Denon with my old A7's I did notice a slightly cleaner sound with better separation when "Bi-Amped" but nothing like having two amps feeding them.
  • gce
    gce Posts: 2,158
    I Bi-Amped my A7's with my AVR and guess what? It was a waste of time. If you're looking for better sound out of your A7's get an separate Amp or Amp's.
    Anaheim Hills CA,
  • With respect, I didn't ask people to look at my equiptment and comment on how I can get better sound. The question is about impedance. Thank you Upstatemax for the answer of 8 ohms.
    TV: LG 50PS70
    MAINS: Polk RTiA7
    CENTER: Polk CSiA6
    REARS: Polk R1
    SUB: Polk PSW 125
  • Upstatemax
    Cuchulain wrote: »
    The nature of people on this site is to chase better sound. Don't take it personally, it's a passion for people here.
    They also look out for your wallet. Where F1nut is coming from (I think), is that in all reality it's usually not worth the cost of extra speaker wire to "Bi-Amp" with a receiver. It will cost less to use better quality jumpers than stock and not bother with the "Bi-Amp".
    However we also encourage experimentation and trying things for yourself...
    So take them as just opinions and figure out whats best for you. If you stick around you will find that pretty much everyone here will do anything they can to help you out.
  • skrol
    skrol Posts: 3,464
    As others have said, bi-amp with a receiver doesn't work but many claim benefits to bi-wire.
    Stan
    Main 2ch:
    HT:
    Other stuff:
    F1nut Posts: 52,002
    The 8 ohm rating for the speakers in question is nominal as it is with most speakers. Over the frequency range the impedance will be in constant flux going higher and lower. One normally finds the lower range having the biggest impedance drop.
    So, why the question?
    Speakers will stay 8 ohm with or without the jumpers. Short and to the point I take it is what you wanted.
    SCompRacer Posts: 9,122
    edited October 2014
    It is typical for the tweeter to be higher in impedance than the woofer in most speakers. An example, woofer 4 ohms tweeter 8 ohms. That 8 Ohm number is nominal impedance, or an average reading. Ever ride a pedal bike? Like Jesse said, impedance changes. Think of riding that bike in hilly terrain. Harder to pedal uphill than down. 4 ohms needs more current than 8.
    Bi-wiring was mentioned. Using the same amp or AVR to connect to high and low terminals of speaker means bi-wiring to me. This is where the woofer and tweeter have individual cables from the same amp. The possible benefit of bi-wiring is that the cable natural resonances will change and the reflections and standing waves seen by the amplifier may be reduced. Whether or not bi-wiring effects are audible is debatable. One of them try it and hear what happens.
  • F1nut wrote: »
    A while back I upgraded to an AVR with pre-outs so I would have the ability to add amplifier(s) to the mix. I'm now at that point. I asked the question to better understand the power requirements of these speakers if I choose to bi-amp them; knowing amps output power differently based on the resistance their shown. From other older threads I know I need at least 200 watts or more to make these speakers perform their best.
    So I'm considering a 7 channel and a 3 because the center speaker can be bi-amped as well.
    Curious though, how does the tweeter of the CSiA6 get power if it is bi-amped?
    TV: LG 50PS70
    MAINS: Polk RTiA7
    CENTER: Polk CSiA6
    REARS: Polk R1
    SUB: Polk PSW 125
  • BTW thanks for the input from everyone.
    TV: LG 50PS70
    MAINS: Polk RTiA7
    CENTER: Polk CSiA6
    REARS: Polk R1
    SUB: Polk PSW 125
    F1nut Posts: 52,002
    Cuchulain wrote: »
    Got it, thanks. The issue still remains, that would not be bi-amping either. Bi-amping requires a separate amp, each with its own power supply AND the use of active crossovers. I believe if you got a separate power amp for however many channels you desire that you would be more than pleased with the result and forget all about bi-amping.
    To answer your last question, the CSiA6 top posts feed the tweeter, the bottom posts feed the two drivers.
  • BlueFox
    BlueFox Posts: 15,250
    I wonder how many people really bi-amp their speakers. For all the questions and talk, I bet very little.
    F1nut Posts: 52,002
    You mean REAL bi-amping? Yeah, very few.
  • Thorton
    Thorton Posts: 1,324
    I've owned the A7's and now A9's. +1 to nbrowser's recommendation. I have no idea why anyone would biamp the A7's. I decent amp will do fine. Buy a nice multichannel amp for the A7's, center and surrounds (if required) and instead of using multiple channels on 1 speaker use it for other speakers. This way you can spend the money on a quality amp instead of more channels (quantity) to one speaker. Or just purchase a 2 channel amp for the A7's and run the rest with the AVR...that's how I started.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
    BlueFox wrote: »
    That's because they are told by way of marketing that a receiver can do it. Then they can't figure out why manufacturers lie about it, and a double face palm when they find out their receiver doesn't put out 100 watts for all 7 channels.
    Hard to blame the posters when the manufacturers are being misleading. I guess some due diligence should fall on the user though.
