Re-skinning the Forum
GospelTruth
So, there has been a lot of discussion about how users don't like the layout of the new forum. I showed in some other threads what Polk could do to make the forum look better by editing the stylesheets for the forum site. I figure that's never going to happen and we are left to live with what we have.
Never one to settle, I wondered if there was a way to override the stylesheets for a website within a browser. After a little research and some trial and error, I found a method to make the site more palatable for myself. I wanted to share that with you all so you can do so if you want as well. This is browser specific stuff, so it will only apply to browsers that you install the add on for and override the stylesheet.
Here you go:
Here you go:
- First, you will need to download a plugin for either Google Chrome or Mozilla Firefox and install it. The plugin is called Stylish.
- Once installed, you will see the icon for Stylish in the upper right of your browser. I have an example below highlighted.
- Click on the icon for Stylish and edit the style sheet
- Once open, look at the highlighted fields in the image below:
- You will need to edit the style to save. I called it Polk Audio Forum in the name field.
- You will need to edit what sites this applies to. In the dropdown pick URLs for the Domain. In the free form field put forum.polkaudio.com. This will apply your style to any page under the domain for the forum.
- Lastly, you will need to insert the overriding styles. I am attaching text documents in subsequent comments with the styles in them. All you need to do is put the content of the text files in the code section area.
- Save.
Speakers
Polk 5jr+
Polk SDA 2B
Polk SDS 3.1TL
Equipment
Yamaha RX-V3800 Receiver
Analog Sources: Sony TC-K890ES Cassette, Nakamichi DR-1 Cassette, Technics SL-7 Turntable
Polk 5jr+
Polk SDA 2B
Polk SDS 3.1TL
Equipment
Here is close to the style I was working on before. It's not perfect by any stretch, so please don't critique at this point. I'll try to refine and fix little issues. It's a starting point though.
Main objectives:- Allow widescreen mode
- Segment Comments better
- Clean right hand navigation
- Better font colors for reading ease
You will need to open the SytleCode-001.txt file, copy the code and put it in your Stylish plugin.
The style will give you this look:
Speakers
Polk 5jr+
Polk SDA 2B
Polk SDS 3.1TL
Equipment
Analog Sources: Sony TC-K890ES Cassette, Nakamichi DR-1 Cassette, Technics SL-7 Turntable -
That's pretty impressive! Good work!VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
Worked for me, thanks for sharing.Shoot the jumper.....................BALLIN.............!!!!!
If you want something closer to what we currently have, here's another style you can download (it's attached to this comment)
- Better display breadcrumbs
You will need to open the SytleCode-002.txt file, copy the code and put it in your Stylish plugin.
Speakers
Polk 5jr+
Polk SDA 2B
Polk SDS 3.1TL
Equipment
If there is something you don't like about the forum look/feel and would like to see if I can change it for you all as a group, let me know what you wish was different. I can only edit things through the stylesheet and cannot do any HTML changes using these plugin tools. If you want something like hiding the Share This button that took up it's own thread, I'm pretty sure I can incorporate that type of change.
These changes doesn't remove ANY of the functionality of the forum itself - it just may hide certain things, change the look feel and so on.
Let me know if there is something I can help change using the Stylish plugin. I'll take all your suggestions and put them in a new stylesheet.
Speakers
Polk 5jr+
Polk SDA 2B
Polk SDS 3.1TL
Equipment
You are doing a great job. One question. Is your picture above widescreen? It looks the same to me. Also, can you move the column on the right side to the left side? Thanks.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
I can look at moving the column to the left side. I think that is doable if that's what a lot of folks prefer.
As to the widescreen, yes it is set to expand depending on your screen size. I have the center being 80% of the screen width with this new format. Polk has this fixed at 960 pixels max. On my laptop I can tell, but on my 24" monitor I can really tell. I can set it to be 85% instead of 80% and you could probably tell more so in the attached images.
Try it out and see what you think and thanks for the feedback.Speakers
Polk 5jr+
Polk SDA 2B
Polk SDS 3.1TL
Equipment
Re-skinning ?
Only one dude worthy of that....Rick88. The man has a way with "skin".HT SYSTEM-
lsi 9's -
Something along these lines?You are doing a great job. One question. Is your picture above widescreen? It looks the same to me. Also, can you move the column on the right side to the left side? Thanks.
Speakers
Polk 5jr+
Polk SDA 2B
Polk SDS 3.1TL
Equipment
Good job. Yes. For whatever reason, I prefer that type of thing on the left. Maybe because I am left handed. Too bad Polk is DOA on fixing this forum.Lumin X1 file player, Westminster Labs interconnect cable
No, that's just wrong. Probably because I'm right handed.....LOL
President of Club Polk -
Looks much better. If the sidebar can be moved to the right or left, can it be put at the top or bottom?
That would allow post to actually be widescreen. -
Good point, or make the side bar a separate page. Then just a link is needed to switch back and forth.Lumin X1 file player, Westminster Labs interconnect cable
That would allow post to actually be widescreen.Good point, or make the side bar a separate page. Then just a link is needed to switch back and forth.
Well, those things will require changes to the HTML and how the page is actually built. I agree with you that it would be better to have all that information in something like a header with drop down menus for login, categories, new discussion, logout and so on rather than taking up all that space on the side of the discussions. It would be better web design. However, that's not how the site is currently built and there are limitations on what can be done with the stylesheets. I'm sure it could be done with access to the application itself, but it can't be done by stylesheets alone in this case.
I can always make the "widescreen" wider. Instead of 80%, I can make it 90% or 95% of the page width instead. I can make some changes, do a screenshot and post it later tonight.Speakers
Polk 5jr+
Polk SDA 2B
Polk SDS 3.1TL
Equipment
I was afraid of that. I already tried making the width 100%, works fine but the Polk logo stays on top of everything else, which just looks weird. And it doesn't gain much with the sidebar anyways.
I also noticed the edit button no longer works? I had to turn off stylish to edit this post.
Thanks for your efforts. -
Good job @GospelTruth. The last posts about moving things around prove why it is so hard to come up with the perfect forum layout. Everyone has a different idea of what the perfect forum layout should be. Some people like information boxes on the right, some like them on the left, some like three columns with the main forum in the middle and some people like a forum to be like a clean sheet of white paper with only text and no clutter at all. It's just hard to please everyone. I'm left handed and I like the information boxes on the right. It seems like they are easier to ignore on the right but they are still available when you need them.
- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
- Crossover upgrades by westmassguy
- Marantz 1504 AVR (front speaker pre-outs to Adcom 555)
- Adcom GFA-555 amp · Upgrades & speaker protection added by OldmanSRS
- Pioneer DV-610AV DVD/CD player
- SDA CRS+ · Hidden away in the closet
I don't really care where the sidebar is located on most forums. The problem with Vanilla, is that they take up too much real estate. That makes the post area too small.
I agree. I like a forum to be simple with lots of room devoted to reading and making posts. I hate a long list of sticky posts that make you scroll to read recent posts. I think something worthy of a long term sticky should be added as an item in the main menu. The photo below is an example of what I think a simple forum should look like. It's not based on Vanilla so I it's not useful for modifying this forum. It's just something I've been playing around with.I don't really care where the sidebar is located on most forums. The problem with Vanilla, is that they take up too much real estate. That makes the post area too small.
this has been beat to death ....cut to the chase ... Polk forum is run by Polk and they rule .... they choose what the forum looks like , not us .. we are guest here because we admire/ use polk products ...wanna run the forum ... buy polk ... I mean the company ..just buy it out right & you can run it the way ya want
i guess im a bit grouchy today .... no disrespect to anyone meant
No disrespect taken on my part. We all have a right to voice our opinion. I think most people participating in this thread are just sharing their ideas on forum design. I don't think we are beating it to death. We are discussing changes we would like to see. I don't expect any changes to come from it and I doubt anyone else does.i guess im a bit grouchy today .... no disrespect to anyone meant
We had the perfect forum layout, vBulletin.Political Correctness'.........defined
You're right, this has been beat to death. I'm just providing a way to fix some things that Polk doesn't seem to want to fix that members here wish were addressed. You can fix some of these issues with stylesheets. The intention of this thread was to show folks here how to fix these issues with their specific browsers without altering the functionality of the forum website.
No worries.i guess im a bit grouchy today .... no disrespect to anyone meantSpeakers
Polk 5jr+
Polk SDA 2B
Polk SDS 3.1TL
Equipment
Here's an example with the content container set to 90% width instead of 80% width. Both will allow expansion for widescreen and expand appropriately. I have included what it looks like normally without stylesheet changes so you can see.
Before:
After (90%):
Speakers
Polk 5jr+
Polk SDA 2B
Polk SDS 3.1TL
Equipment
I see you are right about that. Hard to figure what changes that I made could be affecting that, but I'll look into what may be the cause and try to get that fixed.I also noticed the edit button no longer works? I had to turn off stylish to edit this post.
Speakers
Polk 5jr+
Polk SDA 2B
Polk SDS 3.1TL
Equipment
Wow...a lot of good work GospelTruth.
Thank you!2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A
