Polk Monitor 70's tweeters
Looking for a new set!
Thanks,
N.
  • Call Polk's Customer Service
    1 (866) 764-1801
    I am sure they can help.
  • I have a pair of Monitor 50 tweeters. They could be the same thing...I had them send to me when I was having issues with my Monitor 50s, but it turned out to be the amp.
    Never even opened the box.
    Receiver
    Harman Kardon HK 3490
    Speakers
    Polk Audio Monitor 50s
    Subwoofer
    Klipsch KSW-100
    Cables
    AudioQuest Rocket 33s 10ft
    AudioQuest Optilink1 2m
    AudioQuest Alpha-Snake 25ft Interconnect
    AudioQuest HDMI-1 2m
    Alienware X51 R2
    PS4
    Samsung Smart TV 40" 1080p 3D
  • $45 If I recall correctly from Polk when I called about my buddy's m70's awhile back.
    Polk Lsi9
    Polk LsiC
    Polk Fxi3
    Pioneer SC-1222
    Parasound 1200 II w/ Kimber Kable HERO + 4TC
    SVS PB12-NSD (Bash)
    PS4
    Sharp Aquos 55"
    "If your BOLD enough to try it,
    your BOLD enough to make it happen"
    novem wrote: »
    Thanks,
    N.
    May we ask what happened to the old ones ?
    edited October 2014
    He probably blew them! Monitor series tweeters are fairly easy to take out if you clip your amp even a little. The Rti lines have a heat sink behind them that helps them handle things better.
    Not that the Ms are bad, you just can't CRANK a cheap amp with them and do anything but lose them. I have had mine plenty loud with a power amp behind them and have "never" damaged anything!
    To OP, you shouldn't have any problem getting replacement tweeters from Polk but you may want to also check to see if you haven't damaged the crossovers?
    cnh
