Vintage Speaker Specs
I just did a search on the main sight for specs on SDA's. It appears that Polk has done away with the vintage speaker section on the main site. I wonder if they are going to direct people who are looking for info on the old Polks to the forum?
2-channelBelles 22A Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
Best Answer
Answers
  • vmaxer
    vmaxer Posts: 5,120
    xsmi wrote: »
    xsmi wrote: »
    What are you looking for??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • xsmi
    xsmi Posts: 1,801
    I was looking for the spec sheets for the SRS line that they used to have on the old site.
  • vmaxer
    vmaxer Posts: 5,120
    xsmi wrote: »
    Look here:
    http://vr3mods.com/uploads/SDA_Handbook_2011_Rev3.pdf
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • xsmi
    xsmi Posts: 1,801
    I have that. And I actually have "most" of whats on VR3's site. I was just wondering if Polk is going to put the info they on their site is coming back.
  • vmaxer
    vmaxer Posts: 5,120
    Not sure, things have changed here and not so much for the good in my opinion. Save anything you can...
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • I have gone to the wayback machine and grabbed what I thought I may need. for those not familiar ... here is a taste:
    http://web.archive.org/web/20140714021728/http://www.polkaudio.com/products/sdasrs
  • xsmi
    xsmi Posts: 1,801
    edited September 2014
    Yep that's the info. It should be on this new site as well. Maybe it will be added down the road. They must've been concerned about getting the current product info up first. Which is understandable.
    mhardy6647 Posts: 34,915
    Polk moved the vintage section of the website to a new URL
    http://web.polkaudio.com/vintage
    I did not know that! :- )
    Thanks for posting that link; just bookmarked it.
  • cmy330go
    cmy330go Posts: 2,341
    Good to see it's back.
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
