Polk CS350-LS Center
LeftCoast
Has anyone ever heard one of these? Which speaker series does it match well with?
Yes. I am running it with RT-16.
LS series obviously- LS50, LS70 and LS90. Also pairs well with RTA's and even SDA's. I have 2 of them, great center channel speakers. TOTL back in the day....
I used CS350 with Polk SDA-2B, CRS+ and some other polk monitors like 7 and 12.
Worked well.
Thanks everyone. Trying to get an idea....How does it compare to say, the cs400? Would it be an upgrade?
oh duh...nevermind...skip that last post....I need to go to bed.
Seems a lot of people use the 350 with vintage polks. Now that you are in the SDA club, you could go that route. You might also consider the LSiM series center. You're welcome to come have a listen to mine if you'd like.
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, McIntosh C2300, Marantz AV7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Sim Audio Moon 380D DAC, EPSON Pro Cinema 6050 -
Are you using that center with your 2.3tl's dpowell?
