CSI3
Wife found this today at a thrift store. Visually it appears to have had a "normal" life. Has a bit of dust on it. Cleaning time for sure then give it a run. 7shnnseg34bb.jpg
Welcome!
    Cleaned up well, no evidence of smoking/pets. Dust was very fine granular. Grill cover might be slightly "sun" bleached. Trying a different cleaning method on it.
    Screws tightened up did make a change I actually heard. Does not sound bad at all. Will make a good addition to the daughters system.
    Wish my wife was out hunting for bargain audio deals for me, you're a lucky man!
    Two Channel
    A Polk CSi3 in a THRIFT. Oh, the Horror, the Horror! That's hard to believe. I bought mine at a good price from a Polkie on this site. Use it in a bedroom set up with two Rti-4s and a sub. Perfect for a smallish room!
    I'm sure your daughter will enjoy it!
    cnh
    Wife said it was small shop called Mary's "something" treasure thrift shop in Greencastle IN.
    Putting together a 5 ch system for her. I'm assuming it will be used mostly for gaming, movies and then music. Yes I have tried to re-arrange her usage priority to being music first..
Welcome!
Welcome!
