KEF C75 in Walnut Finish - Excellent
KLapinas
This is a beautiful and excellent sounding pair of KEF C75 speakers
Asking $250/pair, for local pick up only
Includes factory box and packaging
http://www.kef.com/html/en/explore/about_kef/museum/1980s/C15_C25_C35_C45_C55_C65_C/index.html
C75 (1988-91)
In the C75 and 95 the Uni-Q array is a type 200_25 - comprising a 200mm (8inch) polymer cone midrange and a coincident mounted 25mm (1 inch) soft dome tweeter. In the C75 this is crossed over to a closed box loaded bass driver to create a floor-standing three way system where the traditional KEF clean and extended bass is matched to the uniform and symmetrical dispersion of the new Uni-Q array.
Specification: C75
System Type: Three-way, floor standing
Enclosure type: Closed Box
Size: 720 x 246 x 256mm (28.4 x 9.7 x 10.1 inches)
Weight: 12.9kg (28.4 lb)
Nominal Impedance: 4ohms
Rated maximum power: 150W programme (into 4 ohms)
Frequency response: 57Hz to 20kHz +/-3dB (-6dB at 47Hz)
Sensitivity: 91dB for a pink noise input of 2.83V (anechoic conditions)
Maximum output: 112dB on programme peaks under typical listening conditions
System: SP3095 (Vinyl finish), SP3096 (veneer)
Drive units: B200 bass unit (SP1237), B200 midrange unit (SP1244), NT25 tweeter (SP1240)
Crossover: SP2135
C75 (1988-91)
Specification: C75
Crossover: SP2135
Location no longer comes up automatically...so you'll need to specify your location.My 7.4.4 DIY 4k Home Theater:
Polk LSiM 707 L-C-R, LSiM702 side surrounds, LSiM 705 rears
Polk LSiM 702s x 4 on the Ceiling Atmos speakers
2 x SVS PB12/Plus 2's
Denon X3700H
Emotiva XPA11 Gen 3
XBox One X 4k & BD and streaming
Panasonic UB-420 4k player
HD-A35 HD DVD
Oppo BD-103D for hirez audio
Technics SL-D2 TT, Grado Gold Cartridge
JVC DLA-RS2000/NX7 projector
Silver Ticket 135" microperf AT screen
Berkline 090 electric recliners with Aura Bass Shakers -
Mechanicsburg, PA
Price Reduction $225
Price reduced $200
Sold
