VTI racks, who has them?
polkfarmboy
Well I have been looking into getting a new rack. I dont want to spend very much money at all and the 2 small mini racks I have were always just for stacking the equipment on. The cheap rack I want now needs to be a little more performance orientated.
I have been looking at the VTI BL 404 as its super cheap and then noticed the much better looking BLG404. The BLG's are the glass shelf version and hold alot of weight and they look good and priced where I want my budget sweet spot.
I have the AGR series and they are very solid. The glass shelves support up to 200 lbs and I was able to stand on it (205 lbs
) Easy to assemble too. Pretty good value. My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
Look at the Sanus a Euro series.
If you shuffle equipment and change around its a great system.
You can get different height spacers and make low racks,high racks,wide racks,whatever.
Modular and solid.
Love the stuff.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
I got this VTI in Feb. courtesy of my brother.
https://us.v-cdn.net/5021930/uploads/attachments/5/4/1/2/3/89401.jpgMarantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
I saw the VTI in Upstairs Audio in Columbia, SC last year and liked it. It's on the list of all the other things I want to do. I've never seen the Sanus stuff. I've been looking for something cheap for my son's system but not having any luck. I have been considering getting myself the VTI and giving him the one I got at Best Buy about a year ago. I'd be interested in some hands on onions on the VTI stuff or other brands that are like the two mentioned. Modular and well built. I personally prefer wood over glass.HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
Additional projects: RTA 12c's -
The VTI stuff is at a great price point for quality/looks. When I was designing my setup i had several spacing questions and their customer support answered all of my questions very promptly. With the AGR series I know if I need to reconfig and need to change a post size that parts are readily available. What I like about the AGR is that you can configure and build a solid immovable unit, but if you need to reconfig you just unscrew the posts. I have 2 60+lb amps on mine and no problems... the glass shelves are rated at like 200 or 250lbs. You can also shop the pricing and apply some coupons to get the price down.My New Year's resolution is 3840 × 2160
I'm on my second VTI rack. First was the BL503 series and now the BL404.
Here is a thread on deadening the tubes. Should anyone go this route, it seems the top caps are thinner now and easier to dent.
http://forum.polkaudio.com/discussion/157082/vti-bl-series-rack-deadening
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
This is actually a VTI 6 shelf unit and an amp stand configured in to 2 freestanding racks.
VTI owner here also. It holds my McIntosh 402 without any issues and it I believe is at the 110 lb mark.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
SCompRacer wrote: »I'm on my second VTI rack. First was the BL503 series and now the BL404.
Man that bl404 looks so much better when you see it in a real world environment. Its got me giving a second thought to the blg404 and saving some money. Can those shelfs be used on there own ie. If I was to go for a blg could I then order 2 extra shelfs and sit a could of mono's ontop of them. I saw an add for the addition shelf and said " cannot be used as a single shelf" ?
I ordered an extra base with shelf to use as an amp stand. My amp has some depth so I had to turn the base sideways. IIRC I ordered them from 4380134d, New Quest Sound, at Audiogon.
I used the 404 for a while (now at college holding my sons system). I originally ordered one additional 7" tall section that gave a lot more options with stacking to form some symmetric custom shapes. Excellent rack for the money.integrated w/DAC module Gryphon Diablo 300
server Wolf Alpha 3SX
phono pre Dynamic Sounds Associates Phono II
turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
speakers Rockport Mira II
cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
rack Adona Eris 6dw
ultrasonic cleaner Degritter -
If you decide to fill the legs with sand or whatever be careful lifting the shelf as the caps can fall off and you will have a nice pile of sand on the floor.Speakers: SDA-1C (most all the goodies)
^^^^ What thsmith said is true...... don't ask how I know
rack Adona Eris 6dw
Always a good idea to fill stands outside if you canMy New Year's resolution is 3840 × 2160
My VTI mishap dealt with lead shot. If one fills the tubes with anything, they should also seal the small slots in the underside where the cross bars meet the tubes. If the rubber plugs in the tubes where the cross bars attach slip out of place, whatever is inside the tube can migrate into the cross bars. If the fill material is smaller than the tiny slots, it can get out. I used a smear of clear silicone sealer.
Rather than use an adhesive of some type on the lower caps, or spray insulation, I prefer the pipe insulation method now to deaden the VTI rack tubes. To add more mass, get some plastic pipe, cut to proper length, cap one end and fill it with material of choice, cap the open end and stuff it in center.
I have a Sanus Euro rack and a Euro amp stand, but that VTI stuff looks pretty sexy for sure, wouldn't mind one myself.Home Theater
Well I ordered the BLG404 in all black with silver caps. Cymax has them for $379 shipped but there was a make an offer on them. I noticed they had them on sale on the ebay page so I used the formula of deduction the ebay and paypal fee's. The offer I put on the cymax web page was accepted so nearly $50 on total savings of the already fantastic low price. Compared to the comp the average price of this rack is$430 so I got mine nearly $100 below that.
This is going to look fantastic with all the new gear I have coming inand cant wait to set it up. Will post some pics on the Friday arrival -
Kewl! Nice rack!
I haven't ordered it yet, but you can purchase the wire management grid separately. The newer racks come with threaded inserts at the rear to attach it. I think it would allow for neater routing of power/IC cables and allow easy attachment points with zip ties.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Scomp l got the rack you can have my cable management grid for free if ya want it bud.
Best looking rack in my eye's for the money, not even any assembley required. They should say on the add ' Polkfarmboy proof ' or ' So easy to assemble, even pfb cant fck it up ' -
All right put it together put some toys on it and lets see it!My New Year's resolution is 3840 × 2160
polkfarmboy wrote: »They should say on the add ' Polkfarmboy proof ' or ' So easy to assemble, even pfb cant fck it up '
That should be a endorsement lol...
"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Will add pics shortly as the dreaded mother inlaw is visiting right now.
Wow 3.8mb upload, I am loving the higher rez pic uploads the forum now has!! -
The black with silver accents look great... congrats PFB!My New Year's resolution is 3840 × 2160
You sir suck!
