Sub Moves
I moved my subs today inside of the of the mains and it is much tighter and has helped balance sub bass levels at all seating positions. I had them in the corners and outside of the mains prior but this is mo better.
Garage | Polk Monitor 5B's
  • Thorton
    Thorton Posts: 1,324
    Very nice system Mikey.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • hochpt21
    hochpt21 Posts: 5,423
    Nice!!! B)
  • BlueFox
    BlueFox Posts: 15,250
    I have never understood the advice many give that sub placement doesn't matter. Out of sight and out of mind seems to be that philosophy.
  • BlueFox
    Yes. Although I rarely use it anymore, I have my LSiW in front of my TV. In fact, the center channel sits on top of it. When I do use it you feel it all over.
  • Room dimensions and furniture placement often dictate where you place subs. It is best, as it has been said before, to experiment with your options and go with what works best that will maintain peace in the household. Peace = Piece.
  • WLDock
    WLDock Posts: 3,073
    Sometimes corners are too much. Wouldn't it be nice to have a dedicated room and a few subs to work with.
