Which SDA inductor buy?
drumminman
I need to get the SDA inductors for my CRS+ upgrades and I have it narrowed down to the Solen Perfect Lay (what I have in my 2.3TL's) or the Solen Hepta Litz. The latter is claimed to be superior by Solen, but I have no experience with it.
Any opinions out there? Bueller? Bueller?
I use perfect lay in my crs+'s, and they are just dandy.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
Do you have the 14 awg?"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
believe so. i bought the same one DK did the writeup on.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
That would be the 14 - you can't go wrong with that. I suppose my curiosity is up since Solen claims the Hepta Litz is the be all and end all . . . and it's only $20 more."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
