SVS Subwoofer question
Hey all losing sleep over this one the wife gave me the ok to put up only she said Only a 3.1 system upstairs since we moved the main HT rig downstairs. I looked at HSU, Velodyne, and SVS, for some apparent reason I keep going back to this one or its little sibling the SB 1000. Does anyone own this particular model or any other SVS and could give me an opinion?
http://www.svsound.com/subwoofers/sealed-box/sb-2000?gclid=CLCmz5uerMACFUNgMgodmHAAtA
  • ken brydson
    ken brydson Posts: 9,008
    I don't own one of those models but I do own a SVS. My suggestion would be to call them. Give them your room size, listening habits, equipment, etc and they'll recommend the right sub for you. Their CS is top notch and they won't try to upsell you.
  • gce
    gce Posts: 2,158
    Kens right, I called SVS and they were very helpful on what would work the best for my setup. Give them a call!
    Anaheim Hills CA,
    gudnoyez Posts: 8,166
    Thanks guys will do but do you think they would be a better choice than HSU, or Velodyne.? Since I can't demo any of these.
  • ken brydson
    Can't go wrong with any of them IMO. SVS offers a 45 day trial with free shipping both ways. Hard to go wrong with that...
  • ken brydson
    You can save a few bucks on their outlet specials...
    http://www.svsound.com/specials/outlet-specials
  • vmaxer
    vmaxer Posts: 5,120
    ZLTFUL wrote: »
    And don't let the "outlet" name scare you Steve. They have the same warranty, are fully factory testing and inspected (cosmetic flaws are the only ones that end up in the outlet) and included the 45 day/free shipping both ways trial.
    They are great to deal with.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • thsmith
    thsmith Posts: 6,082
    edited August 2014
    Don't sell HSU short, they too have great customer service and products. Give them a call while you are at it.
    I currently own a PB13 but have owned HSUs as well. In my former very large room the PB13 did the trick, I wanted 1 sub and I needed 2 of the HSUs in that room.
    My current house the PB13 is loafing and taking it easy and the HSU would be a better fit.
    Most of the HSU's in that $600-$700 price range are down firing ones what's the performance difference between front firing and down firing?
  • null
    I always wondered the same thing.
    Front vs Rear firing- I had the Polk psw10 and have the Polk psw505. The psw10 front firing seemed easier to find a placement VS the rear psw505.
    I never had a downfiring one. So I am curious as well.
    Cheers!
    Polk Lsi9
    Polk LsiC
    Polk Fxi3
    Pioneer SC-1222
    Parasound 1200 II w/ Kimber Kable HERO + 4TC
    SVS PB12-NSD (Bash)
    PS4
    Sharp Aquos 55"
    "If your BOLD enough to try it,
    your BOLD enough to make it happen"
