Have you "snugged" your speaker today?
steveinaz
steveinaz Posts: 19,546
edited August 2004 in Speakers
Just a reminder; I snugged the mounting bolts on all my drivers yesterday, and thought I got a new pair of speakers. Some of them required as much as a half-turn.
FYI: Don't over do it; just snug them, especially if you have plastic bezel rings around your drivers. I use the 2-finger rule, I snug the set-screw as far as I can using my thumb and index finger only.
Cheap tweak that makes a big difference, check them every 6 months.
Post edited by steveinaz on
  • Pauly
    Pauly Posts: 4,519
    edited August 2004
    Yeah i just did that with the Monitor 10's. wanted to make sure no air leaks and they are running at optimal performance.. I also blow kisses at them too :D;)
    Pauly
    Life without music would
    F1nut Posts: 52,009
    edited August 2004
    Pauly, you worry me. ;)
  • amulford
    amulford Posts: 5,020
    edited August 2004
    Nothin' to worry 'bout... HE'S A FREAK!!!:D
  • steveinaz
    edited August 2004
    If I had some cherry monitor 10's I'd sleep with 'em, but thats a whole nother thread....
  • Airplay355
    Airplay355 Posts: 4,298
    edited August 2004
  • Pauly
    Pauly Posts: 4,519
    edited August 2004
    A Phreak with M 10's :)
  • dorokusai
    dorokusai Posts: 25,576
    edited August 2004
    Ok this is one of the more suggestive threads I have read lately....snugging....2 finger rule....plastic bezel rings around your driver....sleeping with speakers....great stuff, I feel at home now :)
    mhardy6647 Posts: 35,242
    edited August 2004
    ... I had problems with loose screws on the woofer of one of my 1974 Klipsch Cornwalls. Discovered this listening to the unbelievable track "Way Down Deep" on Jennifer Warnes' somewhat obscure CD "The Hunter". Had some buzzing on one of the Cornies when it was cranked up. I was afraid I had a dragging voicecoil, but it was nothing more than eight loose screws.
    Definitely worth checking screws for tightness occasionally (every 30 years, based on my experience). Be careful with any driver using self-tapping screws in wood or MDF that you don't overtighten/strip them!
    (now we're talking about stripping AND ****...)
  • amulford
    edited August 2004
    All this innuendo... I'm going for the toolbox, so I can play with my wood:D
  • POLKOHOLIC
    POLKOHOLIC Posts: 407
    edited August 2004
    How do i tell when Ive screwed ttoo much?
    F1nut Posts: 52,009
    edited August 2004
    When something falls off.
  • TroyD
    TroyD Posts: 13,124
    edited August 2004
    I've heard that Caig makes products that are very good a lubricating and protecting your parts.
    BDT
  • Airplay355
    edited August 2004
    don't use armour all
