Needed: Spikes and metal discs for SDA 2BTLs
pglbook
As I mentioned in a previous thread today, a little water got under the bottom wooden cap of one of my SDA 2B TL speakers and I now realize (thanks to the responses I got in the other thread) that I need to get some spikes and metal discs (to put the spikes on as I have hardwood floors) for the speakers to get them off of the floor.
I will buy some spikes and metal discs for the spikes but first wanted to check if any Polkies have any they'd want to sell. I would need 8 spikes and 8 metal discs, of course.
Thanks.
Thanks.
Post edited by pglbook on
Part Express sells a kit of 4 spikes and discs for about $30 per kit.
Not sure if you'll find them any cheaper than that. I've bought several sets for various applications.
http://www.parts-express.com/cat/isolation-cones/1914Main System 2.2:
Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
(2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~ Sansui D-X111R
Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
Home Theater 5.2:
Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Polk Audio RT55i ~ RT35i ~ CS400i ~ (2x) PSW450
Winter Residence 2.1 (laptop system):
Yamaha A-S301 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200
