polk sda 1b once and for all consensus on nad 2200
i really would like to know if this will work with the 1b.
its seems that guys have used it others say no.
nad says yes nad says no.... ive read many posts on this.
it bothers me about the inverted channel and power supply issue.
but..... people say it measures o ohm between negatives? so.......
i can get one for cheap and would love to try it.
any help is appreciated.
Post edited by Dusty B on
afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Looks like two different people sent a request to NAD support. One got a response that it is not common ground, another got a response that it is. Go NAD support!afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
That's what I was reading, I want to hear if somebody has actually used it, haha Go Nad support. I emailed them to and I'm waiting on the reply. It seems that some have used it just not sure if they used it with Blade Blade interconnect the combines grounds.
Thanks nightfall good looking out -
this is pretty clear I guess. I was hoping there was a way to make this work but it looks like no dice?
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&ved=0CDUQFjAD&url=http%3A%2F%2Fwww.vintageshifi.com%2Frepertoire-pdf%2Fpdf%2Ftelecharge.php%3Fpdf%3DNad-2200-Owners-Manual.pdf&ei=QmTNU4WIOZHeoASH2YDABw&usg=AFQjCNG3tWP83QpLShAS2yFL7_88-zhbQw&sig2=hbWA-SvyuYpJzlj0o_PyLA&bvm=bv.71198958,d.cGU -
I just said forget it on the nad, just bought a GFA 555.
You will like the Adcom GFA 555. What pre amp?
B&K pro 10mc
is on its way. -
I used an NAD 2200 for a long time with SDA's, no problem.
http://www.polkaudio.com/forums/showthread.php?65774-I-m-done!-The-coolest-2-channel-stereo-I-ve-ever-owned
Funny to see that thread again now after all these years, only thing I still have from that setup is the Squeezebox power supply and the Signal cables!Good music, a good source, and good power can make SDA's sing. Tubes make them dance. -
curious to hear your thoughts on the Pro10. I have the MC-101, picked up locally last winter, included with an EX-442 amp. I had no idea that it would sound better than anything else I was playing with at the time.B&K pro 10mc
is on its way.I disabled signatures. -
just open the thing up and look how its grounded...take 2 seconds...Marantz 1152 DC- Denon DP 1200, Soundsmith Carmen MKII- ADS L980 - Blue Jeans IC's
Again, the NAD 2200 is good to go with SDA's.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
