Did MIT produce power cords to match the Terminator II cable line?
gudnoyez
gudnoyez Posts: 8,161
I got my Signal Cable Magic power cord for my Adcom to match all my Signal Cable speaker cables and IC's in my HT rig and am very happy with the results, and was wondering if MIT made power cables that would be a good match with my Terminator speaker cables and IC's and if not should I just get another Signal Power Cord?
Post edited by gudnoyez on
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited August 2014
    I would say the z cords would be what you should be looking at. I had one in the system for a short period of time and it was a nice little instant upgrade, not as good as the 4 foot oracle ziii I hooked up shortly afterwards. With these cords you really only notice or get your moneys worth when paired up with much more transparent components.
    edited August 2014
    I saw those on the MIT web site but price was not listed, a little hesitant to pursue the cost figured they are pretty pricey.
  • polkfarmboy
    edited August 2014
    If you search them out you should be able to pick a 1m cord up for around $125. They do come up quite regularly so it should not be too long before a listing pops up.
    edited August 2014
    http://www.usedcables.com/Product/MIT--Z-Cord-with-Schuko-Euro-Wall-Plug--6-5ft-2m--Power-cable
    Has anybody bought from these guys? Oops looks like a 220 Euro plug the search continues.
  • headrott
    headrott Posts: 5,496
    edited August 2014
    gudnoyez wrote: »
    I have purchased some used speaker cables from the one time. My experience was a positive one. Accurately described condition. The used price is sort of average, not spectacular however. Hope this helps.
    heiney9 Posts: 25,431
    edited August 2014
    I have 4 of the original Z cords. They are nice. Those would be comparable to the Terminator series.
  • polkfarmboy
    edited August 2014
    I would get into some pangea cords particularly the ac9se as they are better than some really overpriced ac cables I have had in my rig as of late. When you say matching MIT ac cables, is this something like when I match up some hitops with a shirt to compliment my skinny jeans?
    edited August 2014
    Something to that sort I matched all my Signal cables Speaker, IC' s and Power Cords on the HT now I want to match my MIT Terminator II cables and IC' s with a comparable power cord like H9 just mentioned, hey Brock have any Idea where I can find some original Z cords? I guess I will start with E-Bay thanks guys.
    edited August 2014
    http://www.usedcables.com/product.aspx?iid=7535&mid=6555&cid=-1
    How about this MIT Z Power cord will this do?
