Speaker settings
For those with the RTi10 (or equivalent) and higher models, do you set your front speakers to LARGE?
I have an HK 525 receiver which allows you to set the speakers to whatever you like. Should I set the fronts fairly low, to something like 40 Hz? Hadn't played around with the settings yet. Just wondering what others have experienced.
BTW, my sub is an SVS PB-1.
Thanks.
Thanks.
HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
YesOriginally posted by Early B.
For those with the RTi10 (or equivalent) and higher models, do you set your front speakers to LARGE? -
well the subs on your 10's are high passed at 125 hz, so if you set the xo at 80 you are still using the subs, just not very much. i think the best way would be to mess around with the xo. try it at 60 hz, 80 hz and with the speakers set to large. 40 hz is probably two low to go. then keep the setting that sounds better, good luck.
