Do MIT cables need to break-in when new gear is rotated in?
GlennDog
Splane Lucy!
I recently replaced an Adcom 5802 amp with mono tube amps (maybe temporarily, as I'm eyeing a Pass X250.5)
Initially the sound was veiled, very veiled. But around 50 hours later, the sound changed completely. Vail lifted and the sound is wonderful . . .
What would cause the change? The MITs were in the initial set-up & re-used but had to be twisted/turned/repositioned to make the necessary connections
TY
G
TY
G
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12
Post edited by GlennDog on
Also, with the new amps & re-positioned cables, the gain was diminished (I had to raise the volume higher than normal) and now it has stabilized . . .???AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
More than likely, it was the caps in the tube amps reforming.Political Correctness'.........defined
President of Club Polk -
This is my first tub amp, can you elaborate a little?? Code for I dont understand . . .
What is caps in the tube amps reforming?
TYAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
Apparently, I cant spell either . . . it's been a long day!
Why do caps (capacitors) need to reform?
ty, JesseAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
When high voltage electrolytic capacitors used in tube amps aren't used for a while the internal materials tend to deform/degrade and with that, their performance. Ideally, the amp should be brought up on a Variac (think slow trickle charge) as to not shock the caps back to life, which can cause bad juju the worst being exploding caps. Anyway, as the caps go through the charge/discharge cycle again the internal materials reform.Political Correctness'.........defined
I should add.....I was assuming the tube amps were used and not powered up for a while. If they are new amps, the caps have to form, otherwise known as burn in, like any new piece of gear.Political Correctness'.........defined
OK, thanks for the info!!
The amps are used, about 3 yrs old, I confirmed this with the manufacturer
Not sure how long they were sitting prior to me taking delivery. I don't think very long. Tubes are KT120s and I know almost nothing about them except its a new design and tube rolling options are very minimalAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
You should be able to run KT88's, but the amps won't put out as much power.
If the tubes were new, they need to burn in as well. I've had power tubes that took 300 hours to settle down.Political Correctness'.........defined
Input appreciated, Jesse . . .AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
You did check/set the bias and recheck later....right? That is if they aren't self biasing. So, what amps are they?Political Correctness'.........defined
yep, checked bias after fully warmed-up. It's been about 2 weeks, I'll recheck bias tonight to see if it changed.
Each amp has 4 KT120s and each tube is biased individually. I'm still playing with the set-up and was going to post a thread when it's settled-in . . .
I've gone Rogue
M-180s
Thanks for the input!AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
Skip,
There's a triode & ultralinear switch that can be changed back/forth on the fly. Something I'm not comfortable with, just old-school,
I feel like it should be shut down before I make changes....
The owners manual sez " for loudspeakers that demand high levels of power ultralinear should provide excellent sound and plenty of power" . . . IT SURE DOES!!
I can't find any published output wattage for when it is run in triode mode. I'm gonna call Rogue to enquire
So far, I'm a very happy camper!!
GAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12
