Tube Preamp
Faustin
Faustin Posts: 1,151
edited July 2014 in 2 Channel Audio
I am thinking about looking into a tube preamp. Some of the DIY amps look intersting. Anyone have any thoughts or experience with Bottlehead components?
Post edited by Faustin on
    mhardy6647 Posts: 35,029
    edited July 2014
    I have an old Bottlehead Seduction phono preamp, which is OK, and a very early pair of Paramour SE 2A3 monoblocks, which (given their price and simplicity and parts quality) are very, very good. I also actually have a NIB, unbuilt Bottlehead Foreplay (I) preamp... but that's another story entirely.
    I also have one of the cute little $99 Quickie battery preamp kits to build -- gotta get around to that some day. We had a chance to listen to one with my "big" SE 2A3 amp (based on the JE/Angela Labs "Simple 2A3" design) at a get together last November, and it (the Quickie, that is) acquitted itself quite well, I thought. That's why I got one for myself ;-)
    Doc, "Queen" Eileen and their crew are good folks. Their philosophy isn't for everyone, and their stuff isn't exactly cheap anymore (with the exception of oddities like the aforementioned Quickie) but their hearts, and ears, are largely in the right place and my experience across nearly two decades (!?!) is that their customer service is top-drawer.
    Not sure if any of that helps, though.
    11037513993_6d37a64ffd_b.jpgparamours 112413 by mhardy6647, on Flickr
  • Faustin
    edited July 2014
    Thanks for the input mrh. Was thinking about the Smash pre. The Quickie sounds intriguing but thought I would spend a bit more money on something.... $300 - $400. Other options or suggestions are welcome.
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited July 2014
    In the 400.00 range youight look into the well liked DARED pre. Very nice in that price point, comes with remote as well. Dozens of threads on the cp too read.search them. Well worth looking into. What amp and speakers are you going to use??
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • Faustin
    edited July 2014
    Thanks for the input. I would use the pre with my Adcom GFA 555 and Marantz CD 5004 player. I currently have an Adcom GPT 500II pre, I run a set of SDA 1c's that are modded or modded RTA 12c's with Peerless tweets on that set up.
  • soundfreak1
    edited July 2014
    I ran a parasound 1200 , rta12c's with the dared and it was beautiful. The polks like the dared very much. Far beter than the adcom pre.more detail less boomy, smoother highs.and you can have fun tube rolling.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • Faustin
    edited July 2014
    Contemplating a Dared SL-2000a with remote for $379.00. It is supposedly a demo unit with approx 20 hours on it. Any thoughts on price? Is there any way to determine how many hours may be on it?
  • soundfreak1
    edited July 2014
    Thats a reasonable price. Are you getting it from dared? Hours are not important as recomend tube upgrade anyway.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • Faustin
    edited July 2014
    Not sure where it is from. Saw it on Ebay. The same seller has a couple of new ones also. Approx 50 miles from where I live. May be an audio shop?? He is advertising a new unit for $469.
  • Faustin
    edited July 2014
    Ended up purchasing the Dared SL-2000a yesterday. Was going to get the demo unit for $379 but for whatever reason it was not working properly, so he sold me a new in the box unit for the same price. Listened a little last night and I am liking it. Now I suppose I will start the "tube" journey. Looking for thoughts on different tubes to replace the ones that came with the unit. Some of the nos tubes sound interesting but not sure if some are considered better than others. I was reading an article that was talking up the 12AT7 RCA black plate from back in the day. Also, what is the burn in period for tubes? Is it the same 200 - 300 hours like the caps on a crossover rebuild. Let the opinions roll.
    tonyb Posts: 33,072
    edited July 2014
    Send H9 a PM, the man knows that pre inside and out and which tubes work well.
  • soundfreak1
    edited July 2014
    tonyb wrote: »
    Ditto! I went to nos RCA'S to Seimens nos to Telefunkin matched nos. Lots of choices.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • dhart86
    dhart86 Posts: 1,594
    edited July 2014
    I definately recommend the Brimar rectifier tube or mullard. When I had the this pre amp I also used RCA and Psvane 12at7 tubes
    I really liked the Brimar/psvane combo
    Main Rig:
    Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
    Second Rig:
    Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded)
  • soundfreak1
    edited July 2014
    +1 on the brimmer type rectifier.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • Faustin
    edited July 2014
    Thanks for the input. Seems like the Brimar rectifier is getting harder to find. Ben doing some searching for any rectifier and the pickings are slim and expensive.
