Demo speakers
rflowers
rflowers Posts: 2
I am looking for a place to demo Rti A3s in the Ann Arbor, MI area. I cannot find any stores that carry these speakers other than on-line. I have used the "where to buy" function on the Polk website, but none of these locations carry these speakers in the store. Based on the reviews I have read, I would really like to listen to these speakers before I make my buying decision.
Post edited by rflowers on
    F1nut Posts: 51,917
    edited July 2014
    If I'm not mistaken you can buy them at Polk's eBay store with a 30 day return policy.
  • rflowers
    rflowers Posts: 2
    edited July 2014
    Actually, it is a 14 day return policy with a 15% re-stocking fee. Not a great plan for reviewing a speaker. Any good advice?
    F1nut Posts: 51,917
    edited July 2014
    I'm trying to decide if you're being snarky or not....jury is out and so am I.
  • pumpkinman
    pumpkinman Posts: 10,291
    edited July 2014
    I don't see the RTI A3 at the eBay Polk store.
    Can you provide a link ??
    Because I am The Pumpkinking
    edited July 2014
    Flowers....they make a good Pinot Noir for around 45 bucks.
    edited July 2014
    pumpkinman wrote: »
    I don't see any either. But they come and go depending on stock. There are some Rti-6s for $199, I believe, which is a VERY good price. Essentially the same speaker as the Rti-A3s in a square box instead of the newer tapered design. Worth a listen if you're building a surround system.
    cnh
