Soundcard vs. USB DAC
rromeo923
Hi all.
Right now I have a external soundcard a Creative Sound Blaster and it is probably 7 yrs old etc. This is connected usb from computer and via rca to a pre (analog only) etc. Would I be better off just using the computers regular sound thru a USB DAC??
I got static in my head
Post edited by rromeo923 on
This DAC's main job will be PC via USB to DAC out to RCA to Conrad Johnson pre. or possibly other analog Integrated etc. What do u think?? Any suggestions?I got static in my head
The reflected sound of everything -
The usb DAC would work much better in my opinionHome Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
Is the computer USB asynchronous, and will the DAC accept asynchronous USB? If not then it might be a toss up as to which is better.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
I don't know. Hmmmm. How does one find out? Guess I should look up what asynchronous means.Is the computer USB asynchronous, and will the DAC accept asynchronous USB? If not then it might be a toss up as to which is better.I got static in my head
The Creative is a USB DAC....
What you're using is already a USB DAC, the question you need to ask yourself is if you want a better one. That all depends on what you're doing with it and how much money you want to spend. For games what you have is fine, but for music playback you can certainly do better for not much money, but that also depends on what kind of files you're playing and what software you're using.
I dont play games on computers. A Pinball machine would be more my style. I use it to listen to music. Watch concerts etc. Do you have any suggestions on a USB DAC used for say $250 or so? Would that be a noticeable sound improvement?
ThanksI got static in my head
The Peachtree Dac it-x is currently on sale for $299. Previously sold for $499.
Two Channel Setup:
Speakers: Wharfedale Opus 2-3
Integrated Amp: Krell S-300i
DAC: Arcam irDac
Source: iMac
Remote Control: iPad Mini
3.2 Home Theater Setup:
Fronts: Klipsch RP-160M
Center: Klipsch RP-160M
Subwoofer: SVS PB12NSD (X 2)
AVR: Yamaha Aventage RX-A2030
Blu Ray: Sony BDP-S790
TV Source: DirecTV Genie -
That's your gut feeling huh? Somehow in a technical discussion like this, I think the OP was looking for responses with a little more substance than that.
lol -
Hi all.
You would be better off with an external DAC yes. For example I find my DacMagic to sound MUCH better than the onboard soundcard. I found the DacMagic to even be better than the DAC in my Sunfire TGP-II. I go coaxial from my PC to the DacMagic and then RCA from the DacMagic to my pre-amp."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
He asked for an opinion and I gave it, Bozo.Gatecrasher wrote: »That's your gut feeling huh? Somehow in a technical discussion like this, I think the OP was looking for responses with a little more substance than that.
lolHome Theater
Two Channel
What did you use to formulate your unsubstantiated "opinion"?
Flip a coin?
Ouija board?
Eenie, meenie, miney, mo?
Pin the tail on the donkey perhaps?
Surely you base your unadulterated "opinions" on technical issues like this on something of substance or is it more like a feeling you get in the left side of your.............. body.
lol -
Yes, read, read, read! There is so much to learn. Still learning myself.I don't know. Hmmmm. How does one find out? Guess I should look up what asynchronous means.
Computer Audio, The Basics
http://www.hifi-advice.com/Computeraudio-part-0-Basics-info.html
USB-synchronous-asynchronous-info
http://www.hifi-advice.com/USB-synchronous-asynchronous-info.html
Asynchronous USB Audio Class 2.0 Explained
http://amimuse.com/2012/09/asynchronous-usb-audio-class-2-0/
Best PC Audio Solutions
http://www.hifi-advice.com/best-PC-audio-solutions-info.html
There are so many out there. Read as many reviews as you can....should give you some ideas.Do you have any suggestions on a USB DAC used for say $250 or so? Would that be a noticeable sound improvement?Thanks
http://www.macworld.com/article/2089224/usb-dac-review-six-compact-components-for-upgrading-your-computer-s-audio.html
http://www.whathifi.com/news/best-dacs-to-buy-in-2014
http://www.crutchfield.com/S-6QHpZliTsOK/fg_371850_FFCustomer_Rating%7C%5Brank1%5D5%20stars%5Bimg%5D/Best-Desktop-USB-DACs.html?XVINQ=DST&XVVER=AAA#?nvpair=FFCustomer_Rating%7C%5Brank1%5D5%20stars%5Bimg%5D&avf=N&price=140-400
http://www.hometheaterhifi.com/dacs/dacs-reviews/meridian-explorer-usb-dac.html
http://www.computeraudiophile.com/content/428-peachtree-audio-dac-it-review-aka-dacit/
http://www.computeraudiophile.com/content/505-meridian-explorer-usb-dac-review/
http://www.computeraudiophile.com/content/536-meridian-audio-director-usb-dac-review/
http://www.computeraudiophile.com/content/487-audioquest-dragonfly-review/
http://www.computeraudiophile.com/content/558-audioengine-d3-dac-review/
http://www.computeraudiophile.com/content/246-cambridge-audio-dacmagic-review/2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Sub 1 - Mirage Omni S8 | Sub 2 - Mirage Omni S8
Are you into pinball machines? I sure am.
As for your sound system, what audio component(s) are you running analog to from your DAC output? The reason I ask is most modern higher-end A/V equipment have pretty-good DACs already on board ready to go. That would be another option to explore. -
So much for the receiver suggestion, though "Eenie, meenie, miney, mo?" just about had me spitting coffee on the screen.
Most all dacs today have a USB input, you can get one just with usb, but then your limited to the amount of gear to hook up to it. More inputs the better in case you want to add a cdp, or something else.
Your CJ pre deserves better, but in the 250 buck range your kinda limited in choices. The Dac Magic mentioned is a good choice for that price range and can be had used for around 200. Keces is also a good choice, Audio-gd, Arcam R-DAC, Peachtree...however you may have to add a hundred or so to that budget.
Will a dac be better than your soundcard ? IMHO....hell yeah, if you can grab a decent dac. I know some here liked the Audioquest usb fly dac, version 1.2 is the best. Single usb input, but can be had for around 100 bucks. Personally though, if you can up your budget to around 400, your choices open up along with sound quality. Musical fidelity M1 used can be had in that area, along with a cast of others. Maybe a PS Audio DL3 too, which may do your CJ pre more justice. Just my .02HT SYSTEM-
