Outdoor speaker set up
thayes34
thayes34 Posts: 10
I have a Denon 3803 and I have a complete 7.1 Home Theater. R50's, CSi 30, Fxi50's, Rti 28's and a SVS sub. I wanted to put some speakers outside on my deck so I bought a pair of Atrium 55's.
The Receiver has a Zone 2 output but I have no idea how this works! I think I need a preamp, which I know absolutely nothing about.
I know when I use the zone 2 output, I am limited to 5.1 on my main system, but I want to be able to switch back to 7.1 when I want to.
Where do I hook up the Atrim 55's to? Do they go to the 3803 or to the preamp?
Please help!
Thanks,
Tim
Post edited by thayes34 on
  • steveinaz
    steveinaz Posts: 19,545
    edited July 2004
    Are the Zone 2 outputs RCA connectors or speaker binding posts?
  • thayes34
    thayes34 Posts: 10
    edited July 2004
    There are speaker binding posts for Rear surrounds or zone 2. You can't have both. I want to use that amp for the rear surrounds to always have 7.1 in the main zone. To use zone 2 and still be able to watch something else in the main zone you have to select zone 2 and you get "variable pre-amp output" (not sure exactly what that means)
    I think I just need to get an amplifier and hook it up to the zone 2 pre-amp connection.
    I know absolutely nothing about amplifiers. Any suggestions?
    Tim
  • steveinaz
    edited July 2004
    Thats what it sounds like, but hard to tell without seeing the back of the receiver.
    Maybe hit ebay or the Polk Flea market for a used amp?
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited July 2004
    Does that receiver have pre-out connections for the zone 2 stuff? If so, you'd just need a two channel amp...
  • fireshoes
    fireshoes Posts: 3,167
    edited July 2004
    Yep, just need a 2-channel amp or if you have an old receiver sitting around, that will work too.
