Wood Finish On SDA's
stogie
stogie Posts: 230
edited May 2014 in Vintage Speakers
How did Polk finish the wood portion (be it solid wood or wood veneer) of the sda cabinets? Is it oil or some type of clearcoat?
Speakers: Polk SDA-SRS xovers rebuilt by David, RDO194's, Dynamat, BH5, glued magnets, new cloth, custom aluminum terminal plates with Cardas posts and Speakon interconnect
Speaker Cables, Jumpers & Interconnect: DIY Douglas Connection
Power Amp: Sunfire Architect's Choice Series II
Preamp: Adcom GFP-750
SACD/CD: Oppo BDP-95
Tuner: Sansui TU-717
TT: Technics SL-MA1
Phono Pre: Emotiva XPS-1
Music Server: Mac Mini w/JRiver - iPad w/JRemote
DAC: Eastern Electric MiniMax Plus
Other Polks: SDA: 1A, 1C, 2B, CRS+ / Monitor: 10A, 5jr, 4 / RT5
Post edited by stogie on
  • jon s
    jon s Posts: 905
    edited May 2014
    I think the SDA had two finishes... Either a vinyl faux wood finish or an oiled walnut finish...
  • GlennDog
    GlennDog Posts: 3,158
    edited May 2014
    Jesse? plz tell . . . ty
    G
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • stogie
    stogie Posts: 230
    edited May 2014
    I also was hoping F1 would chime in. From the posts I have searched, he knows his wood. I was just wondering if Polk was consistent in the how they finished the walnut/oak portion of their cabinets. In particular, I'm refurbishing a pair of SDA SRS's. I have replaced the cloth but the wood looks a little "tired". The end caps are solid walnut and the side strips are walnut veneer. I didn't want to actually refinish the wood, just try to make it look a little better. From what I've read, if the wood is oiled it is best to use something like Watco Oil and if it has a clearcoat finish, maybe a polish like Guardsman.
    TT: Technics SL-MA1
  • PolkieMan
    PolkieMan Posts: 2,446
    edited May 2014
    My 2.3tls are walnut that is just stained and oiled as the were new.
    I refreshed my 1C to look the same, hand sanded with 400 grit walnut stained then tung oil using a fine steel wool then a polished with
    an ole cotton terry towel
    F1nut Posts: 52,002
    edited May 2014
    I've seen SDA's that have an oil finish and others with lacquer.
    Those would have been oiled.
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited May 2014
    I believe my '87 2BS were light white oak w/Laccquer finish that over time dries out and discolors. My were also helped along w/ the pretty plants with to much water stain syndrome. After bleaching and sanding I stained mine medium walnut w/like 4/5 coats of clear poly they were so dry it just soaked it up like a sponge. This was the 1st coat and as and you can see no sheen. Never a fan for light oak for speaker furniture but would always take it over a vinly rap. Granted pix a bit out of focus.
    F1nut Posts: 52,002
    edited May 2014
    Just to be clear I'm not picking on you, Lew.
    One wants the wood used to make any type of furniture to be DRY. The moisture content should be 6% to 8% maximum. You NEVER want to add moisture to wood, period.
    Now, the reason the first coat seemed to soak in so much is because oak is an open pore wood. It wouldn't matter what finish you applied, it would not have any build to it.
