Magnetic grilles on LSiM705 falling
pyrocyborg
Hi!
Ran a frequency sweep today (well... in fact, 4 in a row) at around 85 dB with bass peaks at 96 dB (40-50 Hz) and well, the magnetic grille did fall during the last sweep. Sure thing, I won't be cranking them out at that level anytime soon, but is it something that happens with these kind of grille especially during bass heavy movie effects? ... or maybe the grille wasn't perfectly positionned.
Speakers: Polk Audio LSiM 705, LSiM 703, LSiM 704c
Receiver: Denon X3500H
Post edited by pyrocyborg on
Helps with the visual explosion effects.AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II -
True that... :P Well, maybe the grille was poorly positionned. It didn't do it again. However, I feared that it could have hurt the tweeter while falling but everything seems fine. In a month, I won't be using the grilles again anyways, except when there are visitors...
Receiver: Denon X3500H -
I find slightly bending the grill to where it puts more pressure at the top and bottom works best, don't bend it alot obviously- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Thanks for the suggestion!Speakers: Polk Audio LSiM 705, LSiM 703, LSiM 704c
