Now Back To the Amps!
FrayDog
Now that the wife is happy with her new deck and patio furniture i can start re looking for a replacement amp for the ones i sold to ease some of the cost.... Im looking at 3 amps right now... going to purchase one of them....
1. NAD T973. 7 channels of 140W continuous. 200W 2 channels driven. price is going to be around $500
Need to know more about this amp is it reliable and how does it sound?
2. Adcom GFA-7605. 5 channels 125W continuous. This one is making a popping sound through the speakers... $?
What are these going for? Is it a good amp?
3. Sonance Cinema 5150. 5 channels 165W continuous. i know this company was bought by ati and they are mainly for distribution amps, but it will probably be the cheapest of the 3 coming in around $350 range...
Need some Advice....
Pioneer Elite VSX-82TXS
Logitech Harmony One
Sony bdp-s5100
Klipsch RW12-D
Polk Monitor 75T
Polk CSI30
Polk RT15
Polk M20
Sony bdp-s5100
Klipsch RW12-D
Polk Monitor 75T
Polk CSI30
Polk RT15
Polk M20
Post edited by FrayDog on
Does the Adcom make a slight pop sound that comes through the speakers when you change channels on the tv or select different sources on the preamp or AVR? This possibly sounds like something others have addressed on forums before. Are you trying to keep the budget around $500.00?
The Adcom is on Ebay right now, it says it works but makes popping sound through the speakers when turned on, just need to know if this will cause issues down the road or if its fine? I am leaning twords the NAD just based on the reviews i have seen, just depends on what the 3 amps go for in price...Pioneer Elite VSX-82TXS
Sony bdp-s5100
Klipsch RW12-D
Polk Monitor 75T
Polk CSI30
Polk RT15
Polk M20 -
I would definitely go with the NAD out of those choices.
Ditto take the nad ( amoung those choices)Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
GoNAD!
Yep, another vote for the NAD.
What's wrong with the Sonance? That thing looks like a beast! And from I can tell, it was made by ATI. And folks on other forums seem to be very pleased with theirs. I've never heard their amps but I use to own Sonance's "The Sub" and it was pretty damn good.
For the price, I don't think you can go wrong.Display: Sony 42" LCD
Sources: Harman Kardon DVD-27,
Panasonic DMP-BDT110 blu ray player
AVR: Sony STR-DA2400ES
Amps: Sonance Sonamp 260(fronts),
Kenwood KM-894(surrounds)
Fronts: NHT 2.5
Center: NHT VS-1.2A
Surrounds: NHT Super One
Subwoofer: SVS PB10-ISD
