Best 2 Ch. Power Amp. To Power POLK Audio RTi A9's Under $1000.00 New & $500 Used.
AVTONY2510
AVTONY2510 Posts: 31
edited May 2014 in Electronics
I need an Amp. to cut down on the Bright/Harshness, Something Warmish Sounding..
Post edited by AVTONY2510 on
  • falconcry72
    falconcry72 Posts: 3,580
    edited June 2012
    AVTONY2510 wrote: »
    Why are you only willing to pay half as much for used gear? If you'd spend the grand on a used amp, you would have a lot a great options..
  • BlueFox
    BlueFox Posts: 15,251
    edited June 2012
    How many times are you going to start the same thread.
  • DarkHorror
    DarkHorror Posts: 73
    edited June 2012
    How about getting an EQ or a receiver or pre-amp with quality room correction? Those are going to have a much better chance at getting a sound you like as they are adjustable.
  • B Run
    B Run Posts: 1,888
    edited June 2012
    BlueFox wrote: »
    Apparently 12... He might get an answer if he'd stick to one thread and actually listen to what people have to say.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited June 2012
    Get a tube integrated and enjoy
  • audiocr381ve
    audiocr381ve Posts: 2,588
    edited June 2012
    Parasound HCA amps will do the trick.
  • AVTONY2510
    edited June 2012
    Sorry Guys I Posted It 2x it won't Happen Again...
  • jbooker82
    jbooker82 Posts: 1,627
    edited June 2012
    A Carver TFM amplifers are warm sounding. Something like a TFM-35 250w X 2, TFM-45 375w X 2, or TFM-55 380w X 2.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • bingo727
    bingo727 Posts: 2
    edited May 2014
    I am also looking for a power amp for rti a 7s
    tonyb Posts: 33,065
    edited May 2014
    bingo727 wrote: »
    Buy a subwoofer for more kick.
    tonyb Posts: 33,065
    edited May 2014
    Agreed....great choice for RTI's....or a B&K amp.
  • Irrenhaus
    Irrenhaus Posts: 1,098
    edited May 2014
    Maybe and Adcom 585 or a nice pair of 565....
    HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
  • voltz
    voltz Posts: 5,384
    edited May 2014
    How about a Vincent SP-331 Hybrid Stereo Amp used for $849 from upscale audio, its 150wpc which I use for my 2 channel set-up on PSB speakers, but I do use it on my RTiA7's now & then and it sounds awesome with it and a Vincent Sa-31 pre-amp.
    http://www.upscaleaudio.com/vincent-sp-331-hybrid-stereo-power-amplifier-used/
