Closely Matched Pair Amperex Bugle Boy 6DJ8 ECC88 Tubes
trav0810
This is a tightly matched pair of 1961 Amperex Bugle Boys. Graphics are decent, but not perfect. They both test high on my Eico tester.
$40 Shipped CONUS
$40 Shipped CONUS
The difference between genius and stupidity is; genius has its limits. -Albert Einstein
Sony Playstation 3 for CD and Streaming
Thorens TD320
Modified Carver C-1
Carver TFM 42 and 45 Amplifiers
Polk RTA15TL Speakers w/Decato mods
White Lightning Moonshine DIY Speaker Cables and Interconnects
Thorens TD320
Modified Carver C-1
Post edited by trav0810 on
Would these be a good fit for the Carver Trav?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
if your talking Carver Tube CD player well I'd think YES as it ran 6dj8's as well as the C19 pre...
I would think that they would be spectacular in the Carver CDP.The difference between genius and stupidity is; genius has its limits. -Albert Einstein
Thorens TD320
Modified Carver C-1
White Lightning Moonshine DIY Speaker Cables and Interconnects -
If john passes, I may be interested
Grab them 'Dawg. I still need to find a way to work the 490t into my rig. That could be months from now.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
That is a deal!!I got static in my head
The reflected sound of everything -
Put me in line too..Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
OK Dawg...looks like you are the guy!The difference between genius and stupidity is; genius has its limits. -Albert Einstein
Thorens TD320
Modified Carver C-1
Pm sent. You can answer my question if you have it handy, but I'll take them.
Thanks Mike!
Adminstrators/Moderators...Please mark this as sold.
Thank you Gentlemen!The difference between genius and stupidity is; genius has its limits. -Albert Einstein
Thorens TD320
Modified Carver C-1
Hey Mike, your tubes shipped out today USPS Priority. I tried to send you tracking, but your inbox is full.The difference between genius and stupidity is; genius has its limits. -Albert Einstein
Thorens TD320
Modified Carver C-1
Thanks, try it now.
