Nice Kenwood VR 7070 THX receiver 100 watts per ch x 6 w phono
geppy1
geppy1 Posts: 3,076
edited May 2014 in For Sale (FS) Classifieds
PM for pictures
Still clearing the shelves Nice Kenwood VR 7070 THX AM/FM AV receiver in fairly rare silver. . Features discrete outputs that produce 100 watts per 6 channels into 8 ohms and unlike most AV receivers today it is from 20 20,000hz. In other words full bandwidth ,not the wimpy way things are rated today. Also has an input for PHONO which means you can use a turntable. Pretty nice sounding unit. I do not have the remote but they can be found online and universals will run it. In very nice shape $100 or BO Thanks
The Kenwood VR-7070 has been engineered to merit demanding THX Select Certification, making that high level of home theater performance more accessible than ever. Combining high-end surround sound processing with advanced features, the VR-7070's impressive digital surround-sound processing capabilities include THX Cinema Mode, THX Surround EX, Dolby Digital, DTS, and DTS-ES (Discrete, Matrix, Neo: 6). SRS Circle Surround II creates an incredible 5.1-channel experience with ordinary 2-channel sources like CDs, VHS tapes and even FM radio. Active EQ by DSP tailors the receiver's response to bring the best sound out of whatever type of speakers you have (full-range, satellites, etc) and the type of program you're listening to (Movies, Music, or TV).The VR-7070 delivers 100 Watts into each of six channels in Surround mode, and 100 Watts per channel in Stereo, while its K-STAT Discrete Audio Amplifier, a Kenwood exclusive, helps to ensure the highest possible signal purity. Also included is a full complement of other AV inputs/outputs (including Component and S-Video) and a set of audio/video outputs that let you send your entertainment to a second zone. The included Universal Pre-programmed Remote controls the receiver, your TV, VCR, DVD player, cable or satellite tuner, and select audio components. An IR sensor input and IR repeater outputs let you use the remote to control your entire system even if the receiver is placed in a cabinet, or other non line-of-sight location.
Product Identifiers
Brand Kenwood
Model 7070
Family Line VR
Product Type Home Theater Receivers
MPN VR-7070, VR-7070A, VR7070
UPC 19048146175
Key Features
Channels 6.1
Output Power 600 Watt
Amplifier Output Details 100 Watt - 8 Ohm - 20 - 20000 Hz - THD 0.09% - 1 channel(s) ( center ), 100 Watt - 8 Ohm - 20 - 20000 Hz - THD 0.09% - 1 channel(s) ( rear center ), 100 Watt - 8 Ohm - 20 - 20000 Hz - THD 0.09% - 2 channel(s) ( front ), 100 Watt - 8 Ohm - 20 - 20000 Hz - THD 0.7% - 2 channel(s) ( rear )
Sound Effects Bass Boost, Loudness
Surround Sound Effects SRS Circle Surround II
Sound Output Type Surround Sound
Built-in Decoders DTS Neo:6, DTS-ES Discrete 6.1, DTS-ES Matrix 6.1, Dolby Digital Surround EX, Dolby Pro Logic II
Receiver Tuner Type Digital
Receiver Tuner Bands AM/FM
Connectivity
Coaxial Digital Input Yes
Optical Digital Input Yes
Optical Digital Output Yes
Headphone Jack Yes
Miscellaneous
Remote Control Type Universal remote control
THX certified Yes
Built-in Display Type Fluorescent
Bass Control Yes
Included Accessories AM antenna, FM antenna
Dimensions
Height 6.3 in.
Width 17.32 in.
Post edited by geppy1 on
