interconnect cables
doug owen
doug owen Posts: 4
edited May 2014 in Speakers
I have just purchased a pair of sda 2 speakers. does anyone know where I can buy the interconnect cables or how to make them?
Post edited by doug owen on
  • oldrocker
    oldrocker Posts: 2,590
    edited May 2014
    Welcome to the room, they do come up sale here from time to time.
    MANY here do know how to build them and build them well!!!
  • doug owen
    doug owen Posts: 4
    edited May 2014
    I would like to purchise a pair if someone could call me at 770-441-6505
    F1nut Posts: 51,685
    edited May 2014
    If your speakers use the blade/blade cable you can buy it from Polk. If your speakers are the SDA SRS 2 with the pin/blade cable, you'll have to make one or look on eBay.
  • doug owen
    doug owen Posts: 4
    edited May 2014
    ok thanks for your help
  • doug owen
    doug owen Posts: 4
    edited May 2014
    Hey I just talked with tech support and they said to just use 16g speaker wire and just shove it in the ports . ok here I go . I am going in and wish me good luck.
    F1nut Posts: 51,685
    edited May 2014
    That's a really bad idea, the reason which I hope you don't find out.
